Sudden large decrease in gas mileage - no mods :<
Old Oct 6, 2007 | 05:42 PM
CGK's Avatar
CGK
Don't the K&Ns (the oil from the element degrading in the intake) sometimes affect the MAF?
Old Oct 6, 2007 | 05:43 PM
tripperfx3's Avatar
Originally Posted by Alphex
Brand new Direzza's, 2 weeks old, balanced, inflated, and alignment done. Brand new plugs, 2 months old.
I have just under 13k miles on it.
I don't have a problem boosting, but I'm not always in the boost either.
I did an oil change today, also cleaned, re-oiled the air filter, used an octane booster/fuel treatment, just to be on the safe side and do the easy, DIY things I could think of.
If it's a bad O2 sensor, how do I get that checked short of taking it to a dealership, is it something I can DIY?
You can use something like mitsulogger and check the voltage through logs, or you can back probe the sensor and use a voltmeter and make sure its getting proper voltage. I wanna say it should be 5 volts, but im not 100% sure on that.
Old Oct 6, 2007 | 05:44 PM
tripperfx3's Avatar
Yes they do. The K&N's use too much oil on the filter and it can damage the MAF. I forgot about that. Another thing to check out.
Old Oct 6, 2007 | 05:48 PM
white8's Avatar
Anybody take in consideration that the air is denser......
Old Oct 6, 2007 | 05:51 PM
BluEVOIX's Avatar
Maybe you have a bad o2 sensor (front by the turbo).
Also I've noticed driving with my windows down has a negative effect on MPG's about 2-3 mpg decrease (mostly 45 mph driving).
With easy accelerations, windows up, and low traffic mostly 40-45mph cruise I get about 27 MPG. In heavy traffic conditions it goes down to 21 mpg sometimes.
Old Oct 6, 2007 | 06:03 PM
dodgecoltracer's Avatar
I've also had lower gas millage lately... but I've noticed Ive' been driving more spirited about 4-5 mpg less
Old Oct 6, 2007 | 06:05 PM
sharkm87's Avatar
remove your wing
Old Oct 6, 2007 | 07:05 PM
bluebyu36's Avatar
thats crazy i did not know that
Old Oct 6, 2007 | 07:14 PM
TRUE-GRIT's Avatar
It's just an OEM type drop in filter, not a cone or anything, the stock airbox is intact, it just flows a little better. I thought it didn't need a tune until you go for the full intake kit, etc...
Am I wrong?
Put the OEM filter back in for a peace-of-mind. Drive slower, then recheck your gas mileage. Check to make sure you don't have a gas leak! Good luck!
Old Oct 7, 2007 | 07:51 AM
[Advance]'s Avatar
+1
Old Oct 7, 2007 | 08:01 AM
4G63-KID's Avatar
i think bad o2 sensor. in my tsi when the front o2 sensor was almost dead but not completly dead (my cel never came on) i could barley get 20 mpg. Ever since my new o2 sensor was in i can drive quicker and harder i can avg about 25-30 mpg
Old Oct 7, 2007 | 01:41 PM
evo150's Avatar
try cleaning your maf sensor
Old Oct 26, 2007 | 08:27 AM
bzzbee2's Avatar
190 is when my gas light comes on. and thats where it has come on for the past 45k miles. the only time i get 240-260 on a tank is when i am on a long haul... vegas to LA.
KNN can sometimes be over oiled. you should clean it when its new. then lightly re-oil it. I have always done this and have never had a maf issue.
Old Oct 26, 2007 | 09:56 AM
c_sautter's Avatar
Is it obvious when the tire pressure is off on the stock advans? I only have 7k on my car and I've noticed a bit of a change in my mpg, but I'm chalking it up to the fires here and a dirty filter. But my dumb self hasn't checked the tire pressure yet.
Old Oct 26, 2007 | 10:16 AM
JJsEvo8's Avatar
Haha, that is cause the Evo has a giant pocket behind the driver (some call it rear seats).
Hotevo3
13
Oct 23, 2012 04:27 AM
racer135
19
Feb 1, 2009 08:57 PM
bolio
Oct 20, 2007 01:14 PM
JimmyZ
37
Sep 26, 2006 12:25 PM
BlueEvo04
Oct 12, 2004 10:30 AM
