boost controller
Old Oct 12, 2007 | 09:04 AM
pbc_2007's Avatar
boost controller
ok, how much boost is ok for a stock car. i think it was at about 17-18 and i put it at about 20, is this ok?
Old Oct 12, 2007 | 09:10 AM
TeStUdO's Avatar
Here's your answer:
https://www.evolutionm.net/forums/search.php?do=process
Old Oct 12, 2007 | 09:12 AM
hellcat's Avatar
It can vary from car to car. If you are going to raise your boost, you need to be tuned for it. If you are not tuned you can harm your car. Good luck!!
Old Oct 12, 2007 | 09:40 AM
tnhockey's Avatar
^+1
Old Oct 12, 2007 | 12:42 PM
JDMCT9MR's Avatar
I boosting about 20 PSI's.Runs fine with that.
Old Oct 12, 2007 | 12:44 PM
madmax4499's Avatar
you should at least log it, check a/f and knock.
Old Oct 12, 2007 | 07:56 PM
EiVxO's Avatar
buy some cheap insurance with a set of head studs and have the car tuned and you can up the boost to 23 psi.
Old Oct 12, 2007 | 09:43 PM
krazirob's Avatar
yeah i push up to 23, i just bought a manual forge unos BC so i think i will be able to hold it at the least if not be able to raise it a few.....
