Headlight "twitch"
Old Oct 12, 2007 | 11:14 AM
CidE's Avatar
Headlight "twitch"
Looked around and couldn't find anything on the subject. I've got a 03 evo 8 and I've got a weird issue with the passenger headlight constantly moving up and down by about 2 inches. It has to be some issue with the electronic height control but has anyone else come across this happening? Is it a issue with the motor or something else? Thoughts?
-CidE
Old Oct 12, 2007 | 12:38 PM
JDMCT9MR's Avatar
Its sounds like maybe something is not locked in place on the headlights leveler?Or maybe an electrical issue perhaps?I would try an electric shop.
Old Oct 12, 2007 | 12:41 PM
grillpt's Avatar
Mine does the same thing. It will stop eventually, and it doesn't do it all the time, but I know exactly what your talking about.
Old Oct 12, 2007 | 12:50 PM
BenJ's Avatar
is the actual bulb moving, or is the light pattern "flickering"? Flickering with the HID are common....but the bulb shouldn't actually be moving.
Old Oct 12, 2007 | 12:53 PM
tnhockey's Avatar
^+1
Old Oct 12, 2007 | 12:54 PM
poncho's Avatar
mine does it too occasionally when it the leveling is set at the highest (I think 0)... any other setting it stays in place..
Old Oct 12, 2007 | 02:10 PM
mikiblueeyes's Avatar
mine doid the same, go ahead and put it in the position you want and disconect the adjusting relay on the left of the wheel, that would stop the motor and keep ir from breaking and misaligning your headlights.
Old Oct 12, 2007 | 02:20 PM
j14mp's Avatar
yea def the relay if its the height control going nutty on ya.
If its flickering then thats normal for HID's (like already said above)
bouncing!? then something in your headlights are loose or broken (also like someone said above)-- so i dont even know why i repeated it haha sorry
Old Oct 13, 2007 | 09:12 AM
CharlieGsanD's Avatar
same problem here, but its my drivers side light. seems like the switch cant decide which position the light should be in & keeps adjusting up & down
Old Oct 13, 2007 | 09:52 AM
value's Avatar
^+1
Old Oct 13, 2007 | 02:49 PM
Extas's Avatar
I just noticed my car doing this the other day, I just figured I was crazy. Good to know that I'm not (or am I? muahaha)
Old Oct 13, 2007 | 08:47 PM
Coprocephalon's Avatar
Mine does it too on the driver's side. It's only happened 3 times in 3 years, and it only lasts a couple of minutes. It's like the Evo version of an eye twitch, and I'm not going to worry about it unless it becomes frequent.
Must look wierd to oncoming traffic.
Old Oct 13, 2007 | 09:47 PM
Dapper Dan's Avatar
my friends evo did that and the settings were on 0 if i remember right, i switched it to 1 and it stopped doing it.
96ajh
Apr 20, 2017 03:40 PM
tscompusa
Oct 19, 2015 09:59 PM
recompile
148
Jul 12, 2009 09:23 PM
Shingen
Lancer Troubleshooting
May 20, 2007 10:04 PM
CidE
Dec 25, 2003 11:38 PM
