SunAuto Hyperforce stop blinking
Old Oct 20, 2007 | 05:09 PM
fugiwara's Avatar
The blue LED light on the unit itself stop blinking.
what happened was, I got my car back from body shop, the car was in body shop for 2 months and they replaced the battery for me b/c it was dead. this morning when I pop the hood with engine running, the light doesn't blink anymore, I check the fuse is fine, and car runs normal, what else could it be? also I can't write to my ecu using ECU flash, do you think these 2 problems related?
thanks.
Old Oct 20, 2007 | 05:42 PM
fugiwara's Avatar
anyone?
voidhawk's Avatar
battery voltage too low? could be that's causing both problems
Old Oct 20, 2007 | 05:59 PM
fugiwara's Avatar
I check the voltage w/ my apexi turbo timer it's normal... car starts fine, headlight doesn't dim
Old Oct 20, 2007 | 06:18 PM
fugiwara's Avatar
up
Old Oct 20, 2007 | 07:26 PM
Invoice EVO's Avatar
Veteran: Air Force
My guess is the sun system doesn't work anymore. From what I remember reading if it's not blinking it no worky. Good luck.
Old Oct 21, 2007 | 01:02 PM
fugiwara's Avatar
thx for the reply, that's what I am guessing too, not working. but if it doesn't work the car still starts and drives fine, anyone has this experience?
Old Oct 21, 2007 | 01:09 PM
fugiwara's Avatar
does HKS DLI has LED too? if it does, when its broken does the lights goes off?
Old Oct 23, 2007 | 07:15 PM
fugiwara's Avatar
up
Old Nov 4, 2007 | 03:47 AM
fugiwara's Avatar
anyone has the same problem?
Noremac14
May 7, 2015 11:59 AM
82jiny
Nov 26, 2014 08:12 AM
AlisterMcRae
23
Jun 26, 2012 06:23 AM
MagicManRed
Jun 27, 2011 04:22 PM
Seijuro
Mar 18, 2010 03:09 PM
