Royal Purple
Old Nov 5, 2007 | 09:09 PM
anton406's Avatar
Royal Purple
have anyone of you tried using Royal Purple engine oil? im just curious of its quality and performance thanks!
Old Nov 5, 2007 | 09:11 PM
KS_Evo9's Avatar
Ive used RP and I cant tell a diff from that and Mobil 1. So I gues M1 FTW?
Old Nov 5, 2007 | 09:12 PM
lizzys6/4's Avatar
i saw an episode of HP TV a while back where they had a camaro and put all RP oils and additives in.
Engine oil
Trans fluid
Diff Fluid
Etc and they gained like 8whp but im sure that they were paid quite nicely by RP. Im using M1 but its really up to the user i guess.
Old Nov 5, 2007 | 09:18 PM
EmeryatSTM's Avatar
We use it in our car and have been beating the crap out of it for 45,xxx miles. The car runs 10.6's @134 mph on the stock motor and everytime I pull the valve cover to inspect it, Its as clean as the day I drove it off of the lot!
-Em
Old Nov 5, 2007 | 09:20 PM
anton406's Avatar
-Em
thats good news to me! thanks for the info!
Old Nov 5, 2007 | 09:23 PM
Sgt Blamo's Avatar
I've been using RP for over a year now. I'm getting ready to switch over to their racing blend. After less than 2 weeks of changing my Mobil1 it was black, after 1 1/2 months the RP was still transparent and, how should I say,purplish. I also called RP's corp office and asked about it being 100% synthetic, of which they confirmed it was. Don't believe the rumors, check things out for yourself.
Old Nov 5, 2007 | 09:24 PM
vwjeff's Avatar
I use in my engine and trans
Old Nov 5, 2007 | 09:27 PM
neogenesis's Avatar
No complaints here, also look at amsoil.
Old Nov 5, 2007 | 09:31 PM
yellance's Avatar
about two months ago modified mag had a real good article on oil and the differences in them. royal purple and redline where tops then mobile one and castrol has to do with bonding and friction and the agents each has
Old Nov 5, 2007 | 09:36 PM
red evo8's Avatar
been using it for about 40k between two evos never had a problem
BUCKNAKED's Avatar
Here you go! https://www.evolutionm.net/forums/search.php
Old Nov 5, 2007 | 09:41 PM
anton406's Avatar
thanks!
Old Nov 6, 2007 | 12:13 AM
EvOcHaRgeR's Avatar
I use it haven't had any problems! I check it every now and then and its still purple!
Old Nov 6, 2007 | 12:34 AM
mrbkkt1's Avatar
My first oil change (500 miles) was w/ royal purple, and i used it on my previous vehicles- no problems.
i've been hearing bad things about RP recently, but it's starting to be hard to tell fact from fiction nowadays.
Old Nov 6, 2007 | 01:57 AM
vishus7's Avatar
rp is comparable to amsoil and redline and is CHEAPER! well at least at my local vendor. It runs 6.95/qt compared to 8.95 for redline and amsoil
