Blew a huge hole in motor!!
Old Nov 9, 2007 | 05:08 PM
jrsimon27's Avatar
where you tuned for your mods?
Old Nov 9, 2007 | 05:15 PM
baggedtaco's Avatar
Originally Posted by scottatayamaha
Well the slipping cam gear would of not blown a whole in your motor it would of just bent all your valves. More than likley your engine blew and peices of block and pistons went up and slammed into your valves with enought force to make the cam gear slip. I would look into your blown motor from somewhere else.
well since i havent pulled it apart yet i can not be 100% sure but my guess is
1-camgear moved advancing timing 2-piston hit exhaust valve which cracked piston 3- piston seized up and rod broke 4- crank is now sticking out the front of the motor!
Old Nov 9, 2007 | 05:16 PM
frenchy99's Avatar
Originally Posted by baggedtaco
Well i installed crower 272's and Pro Street adjustable cam gears about 3 months ago... when i installed the gears i noticed the crappy button head allen bolts they give you werent able to be torqued down a whole lot. I figured they were tight enough and there were enough of them not to move..... I was wrong!! this morning goin about 75 on the highway just cruising along i heard all kinds of noise and a bunch of smoke and oil started shooting everywhere! I drifted off the side of the road and knew what prob. happened before i popped the hood. When i opened the hood there was oil everywhere and right in the front of the block there was a huge hole! i checked the exhaust cam gear and just as i thought it was 12 degress advanced!! im pretty mad not just at the crappy Pro Street bolts but at myself... I knew i should have swapped them out but theres nothing to do now but get a new motor....
Did you take pics?
Old Nov 9, 2007 | 05:29 PM
evovin's Avatar
sorry...I was in your situaton 5mos ago! Time to built a monster now!
bigric09's Avatar
very true... and since the torque specs for the cam gears are in inch lbs... i doubt you undertightened them.... hell, i always feel that the proper torque spec is just not enough half the time... .but what can you do
Old Nov 9, 2007 | 05:30 PM
ray3328's Avatar
that sucks man, good luck with the build...
Old Nov 9, 2007 | 08:28 PM
lemmonhead's Avatar
I stopped reading after I read " I figured they were tight.."
Old Nov 10, 2007 | 06:00 AM
baggedtaco's Avatar
Originally Posted by frenchy99
Did you take pics?
Not yet im gonna pull it apart and get some this weekend
Old Nov 10, 2007 | 06:03 AM
methc63's Avatar
The gear was not advanced. It was retarded.
Old Nov 10, 2007 | 06:07 AM
EvoDan2004's Avatar
i have prostreet cam gears. no problems here other then 2 or 3 bolts are striped out. i got all new one's from prostreet but have not put them in yet. mine are tight though. i dont think it was ur cam gears.
Old Nov 10, 2007 | 06:08 AM
baggedtaco's Avatar
Also, I know that a 9 motor wont fit directly in but does any one know if any year evo 8 will bolt directly in? ex. 2004 or 2005. Thanks
Old Nov 10, 2007 | 06:09 AM
baggedtaco's Avatar
Of course
Old Nov 10, 2007 | 06:10 AM
EvoDan2004's Avatar
an evo 9 motor will drop right it. why would it not????????
Old Nov 10, 2007 | 06:11 AM
baggedtaco's Avatar
How do you figure?
Old Nov 10, 2007 | 06:15 AM
evo@24psi's Avatar
Sorry to hear man. Good luck!!!
