Blew a huge hole in motor!!
Old Nov 9, 2007 | 02:09 PM
baggedtaco's Avatar
Unhappy Blew a huge hole in motor!!
Well i installed crower 272's and Pro Street adjustable cam gears about 3 months ago... when i installed the gears i noticed the crappy button head allen bolts they give you werent able to be torqued down a whole lot. I figured they were tight enough and there were enough of them not to move..... I was wrong!! this morning goin about 75 on the highway just cruising along i heard all kinds of noise and a bunch of smoke and oil started shooting everywhere! I drifted off the side of the road and knew what prob. happened before i popped the hood. When i opened the hood there was oil everywhere and right in the front of the block there was a huge hole! i checked the exhaust cam gear and just as i thought it was 12 degress advanced!! im pretty mad not just at the crappy Pro Street bolts but at myself... I knew i should have swapped them out but theres nothing to do now but get a new motor....
Old Nov 9, 2007 | 02:11 PM
chaz517's Avatar
ouch, im really realllllly sorry to hear that man. you defintetly should have at least asked around before you left the bolts untightened and drove away, but im sure you know that now. good luck man
lilman8403's Avatar
sorry to hear that. good luck with the rebuild
Old Nov 9, 2007 | 02:13 PM
Cosmos's Avatar
That really really sucks! I feel for you man.
Old Nov 9, 2007 | 02:22 PM
AndyBandy's Avatar
wow dude, sorry to hear
Old Nov 9, 2007 | 02:44 PM
scottatyamaha's Avatar
Well the slipping cam gear would of not blown a whole in your motor it would of just bent all your valves. More than likley your engine blew and peices of block and pistons went up and slammed into your valves with enought force to make the cam gear slip. I would look into your blown motor from somewhere else.
Old Nov 9, 2007 | 02:48 PM
jrsimon27's Avatar
+1
Old Nov 9, 2007 | 02:50 PM
PANGES's Avatar
I was thinking that also... Good luck man!
Old Nov 9, 2007 | 03:04 PM
rush63's Avatar
I agree with Scottyamaha.
Timing belt and balance shaft belt of my old 4G63 snapped (don't know which snapped first, though) few years back. Valves were bent; valve guides, rollers and pistons cracked but didn't bore a hole through the block. There could be other problem/s that caused the motor to blow.
Old Nov 9, 2007 | 03:20 PM
988evors's Avatar
Ouch! It's a good excuse for more mods, though. Good Luck
Old Nov 9, 2007 | 03:25 PM
C6C6CH3vo's Avatar
If your not married then it's no big deal. Just an opportunity for a new engine with 0 miles.
Old Nov 9, 2007 | 03:29 PM
82NoMe's Avatar
sux bro...I am sorry...
Old Nov 9, 2007 | 04:14 PM
JDMCT9MR's Avatar
Thats lame dude!Good luck!
Old Nov 9, 2007 | 04:50 PM
W0459732's Avatar
good luck mang
Old Nov 9, 2007 | 05:03 PM
CGK's Avatar
CGK
Man, That sucks. Best of luck with the rebuild, Like others have mentioned, not sure your install was the culprit.
