I hit a curb going 20 or so
Old Nov 13, 2007 | 02:11 PM
spyder526's Avatar
I was driving last night and the streets were wet because it was raining and ,since it was raining I couldnt see a curb coming up until a few secs before and I steered away but I still caught the back right wheel against the curb and it got some curb rash and now the wheel itself looks to be curved in every so slightly.....My question is after seeing that the control arms an everything look ok should an alignment be able to fix this or do I need something else done.
Old Nov 13, 2007 | 02:16 PM
suekie's Avatar
well if your wheel is curved, its a bad wheel, not alignment.
Old Nov 13, 2007 | 02:18 PM
scoob2evo's Avatar
ya check that rim to make sure its not bent... sounds like my buddy wolf
Old Nov 13, 2007 | 02:21 PM
boostGotMeLaid's Avatar
does it make any noise??
Old Nov 13, 2007 | 02:23 PM
Wolf28's Avatar
Says the only guy I know who has wrecked 2 Evos...
Blow me...
You know that was my buddy....
....how's your Evo running by the way?
spyder526's Avatar
no it still drives and sounds fine but the tire does look a little deflated now
Old Nov 13, 2007 | 02:32 PM
suekie's Avatar
if it drives fine, then why would you need an alignment? Tires deflated, fill it up?!
Old Nov 13, 2007 | 02:38 PM
W0459732's Avatar
def have it checked out, just to be sure
Old Nov 13, 2007 | 03:30 PM
lysy82's Avatar
if you bent the wheel you probobly need new wheel and alligment !!check the wheel first
Old Nov 13, 2007 | 03:59 PM
threefiftyse7en's Avatar
you might as well do an alignment bro... $50 isn't much to ensure evrything is good to go.
Old Nov 13, 2007 | 04:19 PM
06MRV8Killer's Avatar
Do the alignment and have ALL of the suspension components checked out. Trust me you need to do this. To the naked eye you wont be able to tell if you messed certain things up. Just take it to someone that knows what to look for or if you are mechanically inclined to check it yourself then do it. It also sounds like you are going to have to replace the wheel. I did the same thing to a GS-R I owned and did more damage than I thought once I took it to a friend for a once over. I looked underneath and everything "looked" fine and it wasnt.
Hopefully this isnt the case with you though.GL
Old Nov 13, 2007 | 04:25 PM
PhoPoweR's Avatar
get the wheel/tire replaced and go get it checked if there is any other problems
Old Nov 13, 2007 | 04:58 PM
spyder526's Avatar
yah i made the appointment tomorrow for the allignment
Old Nov 13, 2007 | 08:00 PM
Dont Try To Run's Avatar
yeah get an alignment for sure and a new rim, is it bent?
Old Nov 13, 2007 | 09:00 PM
DSMEVOLUTION's Avatar
My right rear wheel hit a curb sideways 1 year ago when I was messing around in the snow. The car actually went over the curb. All it did was make a slight bent in the lip of the rim. I was spinning around doing donuts in the snow and wasn't aware of the median. (trust me I will never do that again!) I hit it pretty hard, i'm not sure of the force but it was probably over 20 mph. I immediately brought it to an alignment shop and everything turned out fine. I had three shops look over the suspension and nothing seemed out of the ordinary.
The problem is that evo suspensions are made out of aluminum and the slightest force can make it bend. Guys who track their cars hard probably don't even know that their suspension might be slightly bent. THe nice thing about the evo is that the suspension is also fully adjustable so if you were to knock it out of whack you can easily compensate for it. My toe is zero all around with negative 2 camber up from and negative 1 in the rear. The cross toe is zero front and rear.
Your suspension should be fine but I would definitely get it checked out.
