Dashboard Noise
Old Nov 15, 2007 | 06:48 PM
Full Function's Avatar
Hey guys,
I've found a few rattles here and there that might be driving everyone nuts. I know with Pat's EVO, he had a rattle coming from the factory gauge cluster and dash (bottom half against the dash) rattling at idle. There's also the rattle coming from the factory ECU harness that has a weird wire tie that hits a metal bracket under the dash on the passenger side, you can either wrap the tie in electrical tape or cut it off, we did the latter. Then there's the one from the heater and A/C vent that someone else posted about. The last one is the factory clock. Somehow, the little POS rattles, when I push down on the dash, it goes away (for those of you that smacked the dash and had it go away, it was probably it), but comes back every now and then. I think some guy on the Mitsu assembly line was pulling some kind of cruel prank when he put this stuff together, because we fix one, and another pops up.
Jerry
Old Nov 15, 2007 | 06:56 PM
3SgteGuru's Avatar
I have a loud exhaust to drown out the noisy dash.
Old Nov 15, 2007 | 07:03 PM
ottomatic's Avatar
I removed my catback and now everything rattles... however, originally one of my door panels rattled.
Old Nov 15, 2007 | 07:07 PM
EvoHung's Avatar
My dash rattles every now and then but lately I have been getting this annoying rattle. Turns out to be the sunroof. Don't ask me how or why but when I push up against the glass the rattle stops....from that area anyways.
Old Nov 16, 2007 | 10:48 PM
BUCKNAKED's Avatar
I have the same exact problem!!! I searched and found nothing. It only happens on freeways. It rattles like the snake
Old Nov 18, 2007 | 09:16 PM
Coprocephalon's Avatar
My dash has rattled since about a week after I drove it off the lot. It used to drive me nuts. I'd fix one and another would pop right up to take its place. Now I don't even notice. I think of it as just part of the Evo experience.
Old Nov 19, 2007 | 05:23 AM
madmax199's Avatar
If you ignore them, they go away but if you try fixing them they multiply.
Old Nov 19, 2007 | 05:29 AM
Juan Martinez's Avatar
My eclipse windows rattled quite a bit. I got an evo cluster for my es and it is sqeeky. I have one that rattles near my glove box area. Next I have fix the rear dash and other stuff in my trunk.
Old Nov 19, 2007 | 05:31 AM
Oh, I forgot to meation, my eclipse, when I had it, the sunroof rattled untill I replace the railing system. Worked great after that. I would check and see if the window is screwed down to the rails good.
Old Nov 28, 2007 | 09:32 AM
sleeper3's Avatar
Originally Posted by vegasevo9
I am hearing some noise from my dashboard. Like clicking. Is it just my car? My car is completely stock except for an TBE. I have 9000 miles...
Did you find the source?
I have the same exact noise, sounds like a clicking, seems to come from one of the vents near the bottom of the front windshield.
Old Nov 28, 2007 | 12:07 PM
evo8426's Avatar
Originally Posted by Skywarp
Sounds like something I had. It turned out to be the gauge cluster lens.
i have a rattle coming from there also
AWCAWD
Outlander Sport
10
Dec 15, 2015 10:57 AM
that fool joeyy
Lancer How Tos / Installations
Dec 1, 2012 07:38 PM
RalliStone04
Feb 25, 2009 06:00 PM
novabluebyyou
Oct 18, 2007 02:04 PM
xmaciek82x
17
Jun 5, 2007 05:58 AM
