2.3 stroker on IX turbo
Old Nov 17, 2007 | 09:08 AM
4G63 T's Avatar
What should i expect?
Your objective findings and theory welcome
Old Nov 17, 2007 | 09:13 AM
scottatyamaha's Avatar
ummmmm fast spool and good tq. What do you expect people to say??
Old Nov 17, 2007 | 09:36 AM
feldguy's Avatar
The stock 9 turbo is going to run out of air on a stroker....
Go for an FP green, or the 20G....the 20g would be bad ***. There are several on the board, check it out.
Old Nov 17, 2007 | 10:25 AM
4G63 T's Avatar
I expect them to say, their thoughts and experience with the setup
It will be my temp. set up until i got bigger turbo.
Old Nov 17, 2007 | 10:33 AM
JordanS4's Avatar
50 trim and 2.3 is a pretty kickass setup. Stock-like response and spool, I've seen 400/400 on a LOW Mustang Dyno @ 22 psi on 93 only. AEM EMS, 2.3, 50 trim, done.
Old Nov 17, 2007 | 10:35 AM
DTM's Avatar
DTM
You will be fine until you upgrade turbo's.
It will be very torquey and fun to drive in traffic!
But as far as power is concerned it will just come on much sooner and loose top end right before 7200 rpm. At least the peak number will reflect that on a dyno. it will still make very good power.
Old Nov 17, 2007 | 10:53 AM
Swashbuckler's Avatar
I have a 2.3 l stroker on the stock VIII 8 turbo. spool and torque is ridiculous. can anyone say awd drift?
Old Nov 17, 2007 | 12:00 PM
4G63 T's Avatar
Wow..i would expect same scenario...btw which stroker you end up?
Old Nov 17, 2007 | 02:26 PM
chaotichoax's Avatar
a fp green is a 20g...
Old Nov 17, 2007 | 02:40 PM
junction's Avatar
This is what I will have. My stroker is being built by AMS and been tryin to figure out if I should upgrade to a 35R at the same time or just leave the VIII turbo on. I know what my wallet says.
I might save some in labor if I do the 35r now but....
Old Nov 17, 2007 | 02:47 PM
4WS Tuning's Avatar
good autox and street setup.... i wouldnt plan on drag racing... not going to have much power after 6k.....
which means after 100mph in 4th youll have no power.... which means you have to shift to 5th which will hurt you equally...
Cheers!
Old Nov 17, 2007 | 02:50 PM
4WS Tuning's Avatar
correct and the FP isnt big enough for a 2.3 minimum to be used is a 50 trim....
sure it may flow the same and make close to the same peak power... but the power band is different and doesnt make as much power at the higher rpms
Old Nov 17, 2007 | 04:43 PM
PVD04's Avatar
No it's not. The FP Green uses a custom made compressor wheel. The only reason it was ever termed 20g-LT is that in his initial prototypes Buschur used a 20g compressor wheel. When the 20g compressor was replaced with the 5-blade FP compressor the 20g name stuck around.
-Paul
Old Nov 17, 2007 | 04:52 PM
Kc2Buk's Avatar
I asked this some time ago...
2.3 liter IX running a Stock IX 16G Turbo Questions
https://www.evolutionm.net/forums/sh...d.php?t=271476
Old Nov 17, 2007 | 07:46 PM
4G63 T's Avatar
Link very informative...like what i stated, it will be temp.
