exhuast install question
Old Nov 17, 2007 | 01:58 PM
j14mp's Avatar
why wont the springs on the bolts for the downpipe fit into the 02 housing? i tighten the downpipe and the springs just wiggling around.
Old Nov 17, 2007 | 02:06 PM
FedEvo8's Avatar
Spray a little WD-40 on the bolts/springs before installing. Usually a little bit of rust makes it difficult to tighten.
Old Nov 17, 2007 | 02:23 PM
chaotichoax's Avatar
I had the same problem with a no name downpipe I bought
my issue was that the the bolt holes on the dp flange were too skinny...and the spring bolts have a little lip on them right after the threading...the lip didn't fit all the way through the flange holes and it wouldn't tighten down all the way
I just grinded the lip off the spring bolts
Old Nov 17, 2007 | 02:31 PM
meckert's Avatar
Lube and twist...lube and twist...ohh my...
Old Nov 17, 2007 | 02:39 PM
suekie's Avatar
hmmm Have someone that knows what they are doing help you!
