downpipe question
Old Nov 19, 2007 | 04:10 PM
blackoutVIII's Avatar
downpipe question
when installing a dp do you need to keep those spring loaded bolts or regular bolts with the same thread pattern will do with out the springs? fyi, my dp has the flex pipe on it.
Old Nov 19, 2007 | 04:13 PM
JDMCT9MR's Avatar
Well did the DP you are installing come with bolts?
Old Nov 19, 2007 | 04:22 PM
Yeah, but the stock spring bolts could not reach the dump pipe. so i had extra ones that came with the whole exhuast sytem. they were long enough to go through the flange and reach the dump pipe to bolt right on up.
Old Nov 19, 2007 | 04:53 PM
Redline-Z's Avatar
Veteran: Air Force
Ditch the spring bolts
Old Nov 19, 2007 | 04:55 PM
Duh Panda's Avatar
well obviously.... use the hardware the system came with ((:
Old Nov 19, 2007 | 05:54 PM
Skipmaster J's Avatar
If you have the metal flex joint in the downpipe then you can afford to eliminate the flex afforded by the spring bolts
Old Nov 19, 2007 | 08:58 PM
Charles B.'s Avatar
use the hardware it came with or buy some bolts!
Old Nov 19, 2007 | 09:26 PM
thanks everyone.
