aem wideband sesor question
Old Nov 20, 2007 | 05:51 PM
Mike.p's Avatar
aem wideband sensor question
okay, i just got tuned on c-16 race gas...i have ran a total of 10 gallons of c-16 and my wideband sensor fouled i guess...so i went and bought a new one and works perfect...my question is what can i do to keep the sensor from fowling out every time i run 10 galons of c-16?? could i use two spark plug non foulers like you would use to keep frpm throwing a cel light? also my sensor is at my test pipe..im running 35r so i didnt want to put it to close to the turbo.......tuners said it was perfectly fine were it was at...i stated this cause i didnt want to hear i had it to far back...lol
thanks for any feedback.....also i did a search and didnt find what i was looking for...thanks ahead of time
mike
Old Nov 20, 2007 | 07:59 PM
dubbleugly01's Avatar
lead leaves a deposit on the sensor that fouls it out. Heat helps burn that deposit off, but doesn't stop it totally from forming. Running too rich in combo with the race gas will make it worse. If you're using C-16 to putz around town and never really get the 02 sensor hot with WOT exhaust gasses, that's a triple whammy! It might be too far back depending on how you're using the car and how it's tuned.
Old Nov 20, 2007 | 08:14 PM
Mike.p's Avatar
it actually seems to be tuned a little rich cause im on stock motor so we wanted to be safe....i think im runnin around 11.9 -12.2 give or take, on race gas 28 psi. the only time i rune c-16 is when i plan on running so i really do do daily driving with it..just mostly wide open stuff....is there a way to clean the fouled o2 to mabey make it work again?? also would some non-foulers like you wouuld use with test pipes not to throw an cel light work?? also would it be acurate?? also msence i seem to be running a little rich should i move it to my o2 housing? thanks for the help
Old Nov 20, 2007 | 08:18 PM
there's really no way to clean an 02 sensor once it's fouled. Heat is your friend, but once it's fouled, it's fouled. Anti foulers will most likely cause a false reading IMO. I don't know anyone who has tried it, but the fact that it "fakes" out the secondary 02 sensor on stockish cars, I'd bet it would "fake out" the wideband also.
Old Nov 20, 2007 | 08:25 PM
Mike.p's Avatar
yeah true...so then you think i should move the sensor up to the o2 housing being heat is my friend..lol????
kyoo
Jun 30, 2019 12:44 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
EvilRob
Sep 8, 2011 04:50 PM
b16a2delsol
Jan 15, 2011 11:29 AM
Wicked E
11
Apr 28, 2008 03:48 PM
