Intercooler sprayer
Old Nov 23, 2007 | 08:30 PM
lockadam2112's Avatar
Intercooler sprayer
does any know when or how long does the Intercooler sprayer, sprays for and when.
Old Nov 23, 2007 | 08:33 PM
DonHugo's Avatar
the book says it is for lower rpms. I have one and I have manually tried to spray it while searching for a drop of water and found nothing.
It is supposed to make the air coming in colder therefore denser and add hp- i think it is a scam
Old Nov 23, 2007 | 10:15 PM
impreza2darksyd's Avatar
^ check pump or water on front resoivor,.. & i believe it sprays on high rpms, auto mode. Am not sure how long, couple secs.?
Old Nov 24, 2007 | 07:50 AM
newbieEVO8's Avatar
I really don't think that you will actually feel any difference.
I have never turned mine on.
Old Nov 24, 2007 | 08:03 AM
SixOneNine's Avatar
After a few drag runs or auto crossing, intercoolers will heat soak especially stock ones. Heat soak= power drop. The intercooler sprayer helps to prevent that a little.
Old Nov 24, 2007 | 08:13 AM
kaiten2's Avatar
on auto mode it sprays for 2 seconds every 5 seconds. it is used for higher rpms and mainly when the car is undergoing a lot of stress in high temps such as driving up hills when its hot outside.
Old Nov 24, 2007 | 12:42 PM
feldguy's Avatar
I have seen people use washer fluid, alcohol, water and a water/alcohol mix.....
I can't say that I've ever heard anyone reporting a difference. I figure using water on the intercooler would cool the unit down a little bit, but really to prevent heat soak is a much bigger problem than can be solved with a water sprayer. Mine was disconnected.
Old Nov 24, 2007 | 03:35 PM
krazirob's Avatar
the ones i saw were used at lower RPMs since there isnt much wind hitting the intercooler. as you pick up speed you dont really need it since you are creating wind impacted the FMIC.
i guess you could use it all the way around though. dont see it doing much of a difference to where someone could feel it or not...........
Old Nov 24, 2007 | 03:57 PM
FighterPilot895's Avatar
When I had my Evo, I would set it to auto spray. I heard that it only sprays when the air hitting the intercooler is too hot. Whatever the case may be, there will be no difference that you can feel, but you should be able to hear it spraying
Old Nov 24, 2007 | 04:12 PM
TIBOevo's Avatar
i took mines out for the winter. will put back in durring the summer. i never realy feel the difference in power. got kicked of the drag stip for dripping on the track. so i took it out.
Old Nov 24, 2007 | 05:40 PM
Murf's Avatar
the last time my friend and I tuned / logged my car I did a few runs the air temps were over 105..I used the IC spray for a good 15 20 seconds..the intake temps were 3-5 deg cooler the next run.
Old Nov 24, 2007 | 07:21 PM
nightwalker's Avatar
To make the factory intercooler sprayer more effective, you have to add two more nozzles on top so it spray on more of the intercooler, and then use winter formula windshield washer fluid. In the summer, it's noticebly different when setup right.
Old Nov 24, 2007 | 07:59 PM
mineisnine's Avatar
I got a question...
I got a intercooler sprayer kit with a 5lb bottle...which was intended for my vr4. Is it worth putting on my Evo IX??...
I heard it really wasnt worth the effort, but at the same time it doesnt hurt!!?!?...and i dont want to do a dry or wet shot.
NOTE: my car is completely stock.
Old Nov 24, 2007 | 08:01 PM
mineisnine's Avatar
sorry....a little drunk didnt mean to jack ur thread..!!! hahaha
Old Nov 25, 2007 | 03:14 PM
hey its allllll good
