Buschur filter question?
Old Nov 23, 2007 | 10:44 PM
SlowEvo-IX's Avatar
Hey guys just replaced my filter with buschur filter. It came with an L bracket that is supposed to support the intake pipe and filter from moving around. My question...where the hell does this attach to? Please help, thank you all!!
-Don
Old Nov 24, 2007 | 07:10 AM
MitsuJDM's Avatar
I"ll do my best to describe it without a picture. It connects to th lower front bolt of the MAF sensor/filter and to the one pre-existing whole the airbox bolted into to which will be right under the tip on the cone filter.
It's just a support bracket.
Old Nov 24, 2007 | 07:13 AM
newbieEVO8's Avatar
Neither I nor mellon use that support bracket.
It is really not needed IMHO.
Old Nov 24, 2007 | 10:33 AM
mrich82's Avatar
I didn't use the bracket either... intake doesn't move around much without it.
Old Nov 24, 2007 | 04:55 PM
mdinubil's Avatar
The L bracket has a long and a short end. I believe the short end is attached to the bottom bolt closest to the steering wheel or firewall on the filter (one of the 4 that you just attached) When it is attached, the other end of the (L) bracket sticks straight out toward the drivers side front wheel. There is a bolt in the frame that needs to be unscrewed and reused. The instructions tell you to use one of the bolts from the air cleaner that you removed but i did not find it necesassary. I just installed mine a couple weeks ago. Hope this helps
Old Nov 24, 2007 | 07:14 PM
dubbleugly01's Avatar
you can get by without it, no problems.
TwStDeVo
Feb 21, 2017 09:52 AM
MaxKanisha
39
Oct 2, 2007 03:56 PM
drewblueeye
Sep 29, 2007 04:32 PM
jinhaingEVO
11
Aug 6, 2006 08:41 AM
pocoRA
May 27, 2004 11:08 PM
