Any one running a Tial 50mm BOV??
Old Nov 24, 2007 | 02:15 AM
Boost3dxEvO's Avatar
I just drove my car for the first time with this bov... and all it does is flutter.. is this normal? Please help!!
THANKS SO MUCH!!!
Old Nov 24, 2007 | 03:57 AM
akunochi's Avatar
No it is not normal to flutter...
kthanxbai
Old Nov 24, 2007 | 01:42 PM
staatz's Avatar
How much boost are u running? It's really only meant for High-boost applications where the stock bov can't really hold
Old Nov 24, 2007 | 02:15 PM
akunochi's Avatar
Indeed and is also not meant for a car running MAF. You know that entire VTA thing.
Old Nov 24, 2007 | 03:02 PM
Runnerdown's Avatar
Tial has different springs for the bov. Get a softer one.
Old Nov 24, 2007 | 03:22 PM
krazirob's Avatar
yes softer will help. my buddy has one like it and he just cant fluff the gas pedal while cruising. just floor it almost to accerlerate and let off. he got used to it but i would just not go for a big BOV until big boost came around. especially if i were daily drving it..............
Old Nov 24, 2007 | 11:11 PM
I did some research and I have the -11psi uncolored spring that came with the tial.. I didn't realize that they made different springs... which spring is the "soft" one? they have like 6 different ones..
and btw .. with my new setup.. I am running the MAF Translator Gen1 and GM 3" MAF. so I know all about the issues with VTA on an EVO... I am going to be running 25psi.. just installed some ARP head studs...
Old Nov 25, 2007 | 01:10 AM
evonrp's Avatar
isnt the green or red spring the softest?
Old Nov 25, 2007 | 01:38 AM
joeracer321's Avatar
under light load with a stiff spring the BOV will flutter a bit, over 11 psi it should blow off clean, if it isn't then you may have a really stiff spring in there.
Old Nov 25, 2007 | 09:52 AM
TiALSport's Avatar
This is a totally FALSE comment
the spring you have is probably too stiff for the vacuum you are pulling at idle
this is how it's supposed to react
http://www.tialmedia.com/tialbovreaction.avi
Old Nov 25, 2007 | 10:02 AM
TiALSport's Avatar
we have 4 springs...
check this chart and match your vacuum
http://www.tialmedia.com/documents/w3_tial_bov50_sp.pdf
kpt6
Mar 16, 2017 08:09 PM
theblackbeast11
39
Jun 9, 2015 01:53 PM
Mitchubishievo
Aug 31, 2007 10:41 AM
highvelocitykid
Sep 8, 2006 03:07 AM
