Did i buy the right AMS Oil?
Old Dec 9, 2007 | 09:06 PM
Rin Tin Tin's Avatar
This is prob a stupid question and all but i dont want to put the wrong oil in my car. I went to SuperAutobacs to buy some oil and when i went to the the AMS oil section... i didnt know which one to buy . Im not talking about the weight but the type (high performance, european, etc etc.)
Well i bought this
Yes, i am a car noob, but i am trying to learn as much as i can for the Evo.
Though lately ive been reading more threads in Off-topic
And yes i did do a search, but all i found was which brand was better: mobil 1, royal purple, ams, eneos and so on.
Old Dec 9, 2007 | 09:15 PM
chaotichoax's Avatar
that's the stuff
Old Dec 9, 2007 | 09:28 PM
72Tornado's Avatar
D'oh. It's not AMS oil, it's AMSOIL.
Old Dec 9, 2007 | 09:37 PM
TNTRMSKD's Avatar
You're in SoCal so that's all you'll ever need since it doesn't get nearly as cold as it does here in the northeast. But if you're interested, you can also run the SSO series:
The 5w40 Euro blend works well also. In fact outside the US most Evo owners (JDM/EDM) actually prefer the 5w40. Greddy also recommends their GR-2 for our cars, which is the same weight as well.
Old Dec 10, 2007 | 09:31 AM
mplspilot's Avatar
You got the right kind. Now get Amsoil for tranny, t-case and rear diff and make your car happy.
Old Dec 10, 2007 | 11:41 AM
shurikss's Avatar
this is what i use .
http://i222.photobucket.com/albums/d..._qt_300pxh.jpg
http://i222.photobucket.com/albums/d..._qt_350pxh.jpg
http://i222.photobucket.com/albums/d...svg_350pxh.jpg
Old Dec 10, 2007 | 12:58 PM
right now my car has around 2500 miles on it; do i really need to do those now? and if i do, would it make a big difference?
I think i will save these pictures so i dont have to make a thread asking if i got the right product
And thanks for the responses; much appreciated.
Old Dec 10, 2007 | 01:31 PM
lapulapu's Avatar
just wondering if you guys using zero weight are noticing burning more oil
Old Dec 10, 2007 | 04:26 PM
evolved83's Avatar
are you using it and burning oil?
Old Dec 11, 2007 | 10:15 PM
shurikss's Avatar
Slip-Lock™ Differential Additive
you need to stay with factory specs and for all the guys make shore if you using AMS OIL check with factory specs and add Slip-Lock™ Differential Additive (ADA).
it will :
http://i222.photobucket.com/albums/d...da_350_pxh.jpg
Formulated with advanced friction modifier. Designed to eliminate gear-housing chatter in cars, trucks and SUVs equipped with limited-slip, posi-traction and locking differentials. Formulated for use with both synthetic and petroleum gear lubricants and safely replaces manufacturer-recommended friction modifiers.
When making a turn, the outer wheels of a vehicle must travel faster than the inner wheels. It is up to the differential to act as a balance arm, establishing constant equilibrium of torques and forces between the left-hand and right-hand driven wheels. In standard (or open) differentials, power is directed to the wheel offering the least resistance. This works well when making a turn, but in a situation where one wheel is lifted off the ground, it causes the suspended wheel to turn while the other remains motionless.
Limited-slip (or positraction) and locking differentials are traction-increasing devices. Locking differentials transfer all available torque to both wheels. The teeth of the spider assembly engage with those on the locker clutch, causing both axle shafts to operate as one. Locking differentials don't allow one drive wheel to spin while the other remains stationary. Instead, they keep both wheels in drive mode, but unlock to permit different wheel speeds when turning. The engaging and disengaging of the teeth on automatic locking differentials often causes a banging and clunking sound. Manual locking differentials usually use an electric motor or vacuum diaphragm to engage the locker, reducing this noise.
Limited-slip differentials allow different wheel speeds when turning, but when one wheel loses traction, greater torque is transferred to the wheel offering more resistance. Limited-slip differentials make use of friction between clutch plates, as opposed to the meshing teeth employed by locking differentials. Transferring less torque per side, limited-slip differentials are generally smoother and quieter than locking differentials, but still sometimes "chatter" when transferring torque to the wheel with traction.
In some differential applications, a friction modifier additive is necessary to reduce chatter. AMSOIL Slip-Lock Differential Additive is formulated with advanced friction modifiers and is designed to eliminate gear-housing chatter in cars, trucks and SUVs equipped with limited-slip, positraction and locking differentials. It also reduces the banging and clunking associated with automatic locking differentials.
AMSOIL Slip-Lock Differential Additive is formulated for use with both synthetic and petroleum gear lubricants and safely replaces manufacturer recommended friction modifiers. Its convenient flip-top dispenser provides quick and easy application to the gear housing. One four-ounce bottle of Slip-Lock treats differential capacities of two to four quarts. It is not for use in automatic transmissions or other applications requiring ATF.
NOTE: AMSOIL Synthetic Gear Lubes do not require the use of this additive. However, not all differentials respond the same and if chatter is noticed, the addition of AMSOIL Slip-Lock will eliminate it. For chattering differentials not running AMSOIL Gear Lube, this product is an excellent solution to the problem.
http://www.amsoil.com/
