Best source for mini battery?
Old Dec 19, 2007 | 07:28 AM
  #31
dcorn's Avatar
I have a braille battery that weighs 12 pounds and it works fine in my Mustang. Since it's cold out, it does get a little weak after a few days of not driving, but when I daily drove it, I had no problems at all.
Be sure not to forget to turn off your lights with that battery. I left my parking lights on for 20 minutes accidentally (not even headlights) and the car barely started.
Old Dec 19, 2007 | 09:01 AM
  #32
belizelittle39439's Avatar
Anyone know the dimensions or weight for a miata battery?
Also--that odyssey pc680 also puts out a lot of cranking amps;
680 cranking amps for 5 seconds
595 cranking amps for 10 seconds
525 cranking amps for 20 seconds
Though another page on the linked site in this thread says the CCA's are 220.
Old Dec 19, 2007 | 09:03 AM
  #33
Oh and hey check this out!
http://www.septechnologies.biz/index...ROD&ProdID=103 <--- a battery tray!
Old Dec 19, 2007 | 10:00 AM
  #34
Spins4's Avatar
Originally Posted by MR Turco
wow that is a great price. So did you have the mini battery last winter bill? How did it hold up through the cold?
No. This would be the first winter with the mini battery. From the beginning I had wanted to just mount an Optima battery in the trunk, but when I I came across ther chance to buy the alky kit, BR uic pipe, and mini batt kit together for an awesome price, I said screw it and see what happens.
Old Dec 19, 2007 | 10:05 AM
  #35
Spins4's Avatar
Originally Posted by Bonestock!
Go to your local parts store and get a Miata battery. Its 1/3 the size of the stock one and it IS a car battery.
Believe it or not, I did. I went to several parts stores around here. I checked for Civic and Miata batteries, and came up with nothing. Then again, that could just be becuase most of the places around here suck..
Old Dec 19, 2007 | 01:09 PM
  #36
Just got some info from Nisei....
They're going to be coming out with an ETX16 battery kit--with more cranking amps and reserve capacity than the pc680 odyssey. Might be something to look into...
Old Dec 19, 2007 | 02:59 PM
  #37
Jack_of_Trades's Avatar
Originally Posted by Spins4
No. This would be the first winter with the mini battery. From the beginning I had wanted to just mount an Optima battery in the trunk, but when I I came across the chance to buy the alky kit, BR uic pipe, and mini batt kit together for an awesome price, I said screw it and see what happens.
Well, you could always swap batteries with my yellow top if you decide to go with the Optima in the rear
Old Dec 19, 2007 | 04:18 PM
  #38
Good sized battery that should fit with UICP, its a max of 5" wide, compared to the PC680 which is 3" wide.
http://www.autozone.com/R,APP341006/...ductDetail.htm
From what I've read, the Duralast Miata battery HERE is made by the same company that makes the WestCo battery(East Penn). Only $85 and more than likely IN-STOCK isn't half bad. Just not sure if it will fit with a Buschur UICP. Its dimensons are:
Length 7 1/2"
Width 5"
Height 7"
Weight 24lbs
Anyone able to measure the available space with a buschur UICP???????
A far better battery in the elements of winter, plus leaving your parking lights on won't do as much damage as it would to something as small as the PC680
Old Dec 19, 2007 | 05:46 PM
  #39
Spins4's Avatar
I'll see what I can do tomorrow to measure it. The snow mound in front of the car should not be too bad
Old Dec 19, 2007 | 08:51 PM
  #40
Lazyfong's Avatar
Did anybody try this out?
Old Dec 19, 2007 | 10:04 PM
  #41
Heck no, I'm skilled enough to make a simple tray with some aluminum strapping for a few dollars, though it is nicely machined and worth it if you are more into the 'show' look, rather than the 'go' aspect
Old Dec 20, 2007 | 10:52 AM
  #42
Spins4's Avatar
Sure..right after you doing something about that big dooky box in the back..
Old Dec 20, 2007 | 02:41 PM
  #43
I'm not working in your trunk if you have a box full of dooky in there! lol
You could pull out the spare and mount in under the subbox in the spare tire well perhaps. I sure don't see you changing a flat tire with your car,lol.
Old Dec 20, 2007 | 02:52 PM
  #44
Spins4's Avatar
Not what I meant smartass..
Old Dec 20, 2007 | 02:54 PM
  #45
Turbo_Saloon's Avatar
i just got the ets kit and its great!!
