EVO's ABS sucks in the snow...
Old Dec 16, 2007 | 08:38 AM
Ct9aGsR's Avatar
are 235;s ok for the ws-50 ?
Old Dec 16, 2007 | 08:39 AM
6-speed's Avatar
Originally Posted by EvoJoeIX
abs really helps
maybe its how you drive thats making you have braking problems....
you cant expect to brake at the last minute when its snowing, even with the best snow tires
+1.
The Evo's a very good winter car but in the end it comes down to driving style.
If your ABS is kicking in too often then it means your tires are not gripping.
Brake earlier and lighter.
Old Dec 16, 2007 | 08:42 AM
thebluesky's Avatar
Originally Posted by 90GSX-03EVO
I wouldn't do it, because I actually like how the ABS works. However, he was saying that he hates the ABS and prefers to not have it, so I was simply giving him a suggestion as to how he could disable it without tearing up anything in the uninstall process.
I run year long without abs by having pulled the fuse. Though having some driving skill and decent tires help things immensely. Be forewarned, this is not for the inexperienced.
Old Dec 16, 2007 | 08:51 AM
tnhockey's Avatar
yea ik...i have the same problem. i just use the gears to slow me down and pray. turning is no fun either.
Old Dec 16, 2007 | 08:55 AM
wrxedout's Avatar
ABS saved my *** a few times this past Thursday. RI was hit with alot of snow, shut down the entire state. Such a mess! Anyway I was virtually trapped in the city being one of the only cars to safely navigate through the mess of broken down and stuck cars. The ABS worked great stopping me sliding around
Old Dec 16, 2007 | 08:59 AM
Robevo RS's Avatar
Some advanced ABS system are stop working under 10 mph {or km/h }, i'm sure you know the reason why...
Old Dec 16, 2007 | 09:00 AM
Robevo RS's Avatar
Get the Blizzak WS-50. I bought them back when they were like $140 each and they are well worth it. Mount them on your stock wheels and get a set of summer wheels for summer tires.
Also, stop trying to turn while braking. Brake, let off the brakes, turn, accelerate. If you have the WS-50's then just turn to full lock without braking. You'll slide straight for about a second, but then they'll grip and turn the car. Once you're turning, give it some gas to rotate the back end around and then steer with the rear.
that is one tires i suggested him already.
you should get a narrower tire for the winter, it will give you way better handling in the snow.
that is why i said get 225 or, if its fit 215's. Also instead to get 45 get a 50.
but these are good ONLY in snow.
Old Dec 16, 2007 | 09:04 AM
90GSX-03EVO's Avatar
235/45/R17 is the size I have the WS-50's in. They work great and you still have some protection for the rim's lip.
They're awesome on snow and ice, and work just fine on dry pavement. In fact, I'm driving 400 miles one way on Wednesday (From Chicago to West KY) and I have no reservations about driving on the WS-50's for this road trip.
Last edited by 90GSX-03EVO; Dec 16, 2007 at 10:46 AM. Reason: Because I am teh stupid.
Old Dec 16, 2007 | 10:01 AM
revvin9k's Avatar
235/45/R15 is the size I have the WS-50's in. They work great and you still have some protection for the rim's lip.
15's ?
Old Dec 16, 2007 | 10:13 AM
EJEvo's Avatar
Yeah, the Evo's ABS is not nearly as polished as other ABS systems. It locks up way more than my Honda Accord used to, and is as subtle as a joy buzzer, but it isn't so bad as to ditch it. I use the ABS more of a warning system that I've exceeded the threshold than rely on it for stopping.
As far as tire sizes, like others here I would recommend going with a narrower-than-stock tire size. I've got LM-22 Blizzaks in a stock size, and the car still struggles with traction as much as other FWD cars we own.
Old Dec 16, 2007 | 10:45 AM
Originally Posted by revvin9k
15's ?
No. I'm retarded.
235/45/R17
Old Dec 16, 2007 | 10:47 AM
mirebih's Avatar
I had the same problem with the stock tires and I was thinking the same.. but the problem is in tires... I used to step on the brake, and the car would only slide forward, hopping it will stop... so I started just punching the brake a bit, and it was lil bit better... Than I bought Toyos (all season) and now I can stop any way I want, punching it or hitting it hard (except ice)... If you are on budget, buy all season tires that can take you thrugh the snow... toyos were 175 a pieace, but i had a hook up so thats why i bought it... 100 a piece.. Good Luck!
Old Dec 16, 2007 | 12:29 PM
BBS's Avatar
BBS
Better to have abs and slide forward alittle then pull a 360 in the middle of the street.
Old Dec 16, 2007 | 12:34 PM
rcheung's Avatar
I run hankook w300 icebear snow tires for the winter. The only time ABS kicks in is when I brake hard in the snow or on a patch of ice. Other than that the tires grip well enough for the ABS not to engage. Your tires definately sound like the problem.
Old Dec 16, 2007 | 01:49 PM
DanJ's Avatar
I like the evos abs system. it doesn't seem as intrusive as other abs systems in other cars i have driven.
