anyone with a Gtech?
Old Dec 18, 2007 | 03:13 PM
EvoJoeIX's Avatar
well today i just picked up brand new gtech pro SS for dirt cheap. i couldnt pass the deal up, so i just bought it. my question is, im having a hard time getting it to read the RPM's.... it says on their site that on some cars its harder to read the rpms on then others. has anyone else had this problem? i think i could be doing something wrong to, i really didnt have much time to fool with it.
any suggestions?
thanks
Old Dec 18, 2007 | 04:18 PM
ant_turbo's Avatar
Mines reads fine,,,
any suggestions?
thanks
Old Dec 18, 2007 | 05:54 PM
EvoJoeIX's Avatar
i just went out and tried to program the RPM's and it wont read for some reason....
but i did do a quatermile run
i got 13.288 @108.64
had like a 2.3 60ft time (i just spun all through first and the beginning of second gear)
0-60 in 4.6 sec
273 hp
and it doesnt read my torque probably needs the RPMs to read torque
and i didnt beat on the car..
i just wanted to see if it worked, so i shifted real slow and didnt even try to launch it hard
Old Dec 18, 2007 | 06:03 PM
wizzo 8's Avatar
mellon has one. maybe he can chim in and give his opinion. I have the passport gtech which isnt so accurate.
Old Dec 18, 2007 | 06:09 PM
EvoJoeIX's Avatar
im doing everything it says...
but it just doesnt reconize the RPM for some reason
also at the end, it asks me to rev the car and watch the rpms.... and i dont understand why it does this because once i hit okay, it just keeps the rpms on the meter where it told me to rev it......
hopefully someone can help me out
Old Dec 18, 2007 | 06:11 PM
LoCo4's Avatar
Used my brothers for a little while. RPMs were accurate. With the times, being on target with the weight is the what is important. That is what the meter bases it's numbers on.
Old Dec 18, 2007 | 06:15 PM
EvoJoeIX's Avatar
yea my weight is pretty dead on...
maybe off by a few pounds, but i tried my best to make it pretty accurate with a 1/2 tank of gas
Old Dec 18, 2007 | 06:16 PM
EvoJoeIX's Avatar
oh yea, i have my boost gauge wired into my cig lighter...
do you think this could have any effect on reading the rpms?
Old Dec 18, 2007 | 06:21 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Have you scrolled through the different rpm options (I believe there are 30) to see if one matches your actual rpms?
Old Dec 18, 2007 | 06:34 PM
Talon's Avatar
You might have to turn your headlights on to put more load on the electrical system.
Old Dec 18, 2007 | 06:41 PM
MaelstroM's Avatar
i am having the exact same problem evojoe...if u figure out anything please let me know...thanks...
i will try to load the electrical system some more and see if that changes anything
Old Dec 18, 2007 | 06:48 PM
Tvwj's Avatar
should of just got an hks turbo timer. It can do almost what a gtech do. Good luck finding out the problem.
Old Dec 19, 2007 | 12:42 PM
EvoJoeIX's Avatar
not even close...
even if it could, it wouldnt be as accurate and i bet i paid a lot less for the gtech then for the turbo timer.....
Old Dec 19, 2007 | 12:44 PM
EvoJoeIX's Avatar
this is the part im having difficulty with...
could you please explain what i am supposed to do at this screen?
the manual doesnt explain it
Old Dec 19, 2007 | 05:15 PM
Talon's Avatar
Did you do what I suggested? I have one, this is what I had to do... Turn the lights on when you calibrate and every time you use it. That's all there is to it. It may flicker at idle but should be good once your revs climb above 1k.
