headlight leveler/dim
Old Dec 18, 2007 | 11:36 PM
mykrofon's Avatar
ok i know these came on the 03's but is there anyway u can swap them into the 05's if so how would it work....just wondering....
Old Dec 18, 2007 | 11:37 PM
mykrofon's Avatar
oh and is it even convenient?
Old Dec 18, 2007 | 11:45 PM
Skywarp's Avatar
Leveler as in swapping the non HID to factory HID? There is a thread i was looking a while back about this. The schematics in the factory manual will point you in the right direction on how to make your own harness using the factory switch and leveler on the headlights. I have the leveler switch installed and plugged in my car but its just there for looks until I get time to wire it up. If thats what your asking.....
Old Dec 18, 2007 | 11:48 PM
Skywarp's Avatar
Well if you have HID's and have the car loaded it will keep you from blinding people. Otherwise, its cool to make your headlights move around
Old Dec 18, 2007 | 11:53 PM
mykrofon's Avatar
yeah i was just wandering cause i have factory hid's and ive been wanting to do that....so basically all i would need would be the switch and wires and it will be sort of a plug n play type thing?
Old Dec 18, 2007 | 11:59 PM
Skywarp's Avatar
I thought all HID equipped had the leveler system intalled. You sure you have HID's? Your harness on the dash side should have the plug for the lever switch next to the dimmer or fog switch.
Old Dec 19, 2007 | 12:01 AM
mykrofon's Avatar
yeah im sure i have both plugs covered with the plastics...no leveler....as far as i kno only 03's came with it i think
Old Dec 19, 2007 | 12:10 AM
Skywarp's Avatar
So you have an 05 with hid's and no leveling system? If thats the case you might wanna check your headlight housings for leveling motors to control in the first place.
Old Dec 19, 2007 | 12:14 AM
mykrofon's Avatar
dats one of the things i was wondering.....if you could swap it out from an 03 n transfer it to the 05.....thanks for ur help either way....will check to see dat tomorrow morning
Old Dec 19, 2007 | 12:19 AM
Skywarp's Avatar
look at the back of a HID headlight and you'll see what they look like (little black box). Good luck
Old Dec 19, 2007 | 12:40 AM
mykrofon's Avatar
will do thanks for ur help
Old Dec 19, 2007 | 03:07 AM
KcEvil8's Avatar
i have a 05 with HID and it have the leveling switch
Old Dec 19, 2007 | 03:49 AM
spdrcr456's Avatar
yea my 05 mr has the leveler
dsm nexus
Mar 19, 2017 08:01 PM
manthny18
Jan 25, 2017 10:27 AM
e_kobz
Dec 7, 2016 04:37 AM
vr4gasmtt
Sep 13, 2015 11:08 PM
faceman
Feb 25, 2012 12:09 PM
