Extreme Damage caused by Loose Meth Line.
Old Dec 25, 2007 | 09:56 PM
  #31
04AWDTURBOEVO's Avatar
Gee, I am sorry to find this out, Dave, .
Take all the nescessary action to make sure it does not happen again.
I would say it may have been the Hot Intake Manifold that ignated the Meth when the line poped out. I am guessing by looking at the location where the wires melted.
But you also got that new Exhaust Manifold on now. Those Glow Red when you get on it. That could have ignated the Meth too.
Good luck fixing everything. At least like Felix is saying, that it all did not catch on Fire. That would have really blow...
Old Dec 25, 2007 | 10:52 PM
  #32
LilRico's Avatar
**** Phenix, I'm really sad to see this happen to you.... I hope you get this fixed in no time...
Best of luck...
Old Dec 25, 2007 | 11:24 PM
  #33
ray3328's Avatar
Man it's a good thing you stopped when you did or it could have been alot worse. Good luck getting everything fixed.
Old Dec 25, 2007 | 11:52 PM
  #34
gtride's Avatar
He is going to get a complete replacement harness EVO 8 by this weekend from me. so he is well taken care of. No down time at all
Old Dec 26, 2007 | 03:29 AM
  #35
Ph3n1x's Avatar
Best of luck...
Thanks for the words guys, much appreciated
Yes, Thanks again, your a life saver.
Old Dec 26, 2007 | 11:30 AM
  #36
Evotech8's Avatar
Never trusted "push-lock" type fittings running exposed plastic hose near a hot engine. Accident waiting to happen.
Go with stainless braided line with threaded type end fitting from the meth pump to the nozzle.
my 2 cents...
Old Dec 26, 2007 | 02:40 PM
  #37
EVIL_EV0's Avatar
Those snap fittings are junk. Snow performance uses the same kind and many many DSM guys find them to leak or pop out. I had problems with my SP kit in the winter. Going from -10* to operating temp the thing would leak. Very dangerous. I would definately convert that to a SS line like the SMC kits use.
Old Dec 26, 2007 | 02:52 PM
  #38
SlowCar's Avatar
there could be 2 issues here
1 - different tube extruders add certain amounts of plasticizers to make the tubing softer and easier to bend around. Under certain conditions, the plasticizers will leach out causing the tubing to shrink in length and OD. Also make sure the tubing you are using for your 1/4" fitting is 0.25" and not a 6mm tubing, extruders have been known to send the wrong stuff out.
2 - there is nothing wrong with those push-lock/quick fit connections, they are used all over the pneumatic world. To use them right, insert the tubing all the way in/bottom out and pull them out with some force to "sink" the grips onto the tubing. Most of the time you can get away w/o doing that. They do get damaged if the tubing is forcefully pulled out w/o pushing the ring back into the fitting. They are cheap, change them out.
Old Dec 26, 2007 | 02:57 PM
  #39
W0459732's Avatar
sorry mang, it could have been much worse, good luck on the repairs
Old Dec 26, 2007 | 03:20 PM
  #40
mplspilot's Avatar
Damn...I think i can smell burning isolation just by looking at these pics...
Old Dec 26, 2007 | 03:31 PM
  #41
SlowSportSedan's Avatar
thats why i like ss line... screw on with some locktite.... not going anywhere...
thats just one less thing to worry about... if this wasnt the first time why didnt you get the problem resolved the first time to make sure it doesnt happen again?
Old Dec 26, 2007 | 03:32 PM
  #42
SickSilverNLow's Avatar
that suck bro......
Old Dec 26, 2007 | 04:35 PM
  #43
mxpop's Avatar
...check your undies....
Old Dec 26, 2007 | 04:52 PM
  #44
JDMCT9MR's Avatar
That sux.At least there was not more damage.
Old Dec 26, 2007 | 05:06 PM
  #45
TTP Engineering's Avatar
This is correct. The proper way to connect the hose is to push in and yank back which makes the teeth bite into the hose.
Periodic removal and reinstallation will chaffe the end of the parflex hose and will require the tip to be cut off so the teeth will have new material to bite into.
The pneumatic fittings can withstand tremendous pressure. The hose I use on my personal kit is marine grade to 650psi I believe. I have run 36-38psi for 3 years without ever losing a line from a connector.
I really wish we were dealing with the facts, whether there was fire or an electrical short. I am not certain if methanol is a conductor of electricity.
