Tread came right off my tire
So im driving home the other day and I hear something smacking against my wheel well. I pull over and there is an inch thick strand of tread unraveled from my tire. Is this normal for the stock tires to go at 9,800 miles? Also, i have to obviously get new tires. So what is a good set thats not to pricey? I want all season if possible.
I would recommend the Continental ContiExtremeContact, I had those on my last car. Best wet traction I've ever had in a tire. It doesn't snow here, but reviews at Tire Rack give it the highest snow rating in the ultra high performance all season category. Dry grip is acceptable for a 400 treadwear tire. With aggressive driving they lasted 35k miles, with normal driving you'll be above 40k easy.
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
The price is really affordable too, in the stock 235/45R17 they are only $98 from Tire Rack.
When you say "strand of tread" do you mean just from the inside of the tread? Depending on driving habits, 9,800 miles is a long time for the stock A046 as they are very soft with low treadwear. What could have happened is that you let the inside of the tire go bald due to negative camber resulting in the tread coming off.
It's deceptive because the tire looks like it has tread on the outer edge. Only if you take the tires off or turn the steering wheel full lock to one side can you see the entire tread wear.
Forgot to ask: What was your rotation schedule like?
This same thing happened to me on the stocke Advans, they were worn and needed to be changed. The extreme camber wore the inner tread bad and it starts to get into the sidewall. I'm now on Falken Azenzis and the tread wear being 200 is just a little harder than the Advans but the tread block design is much better. Totally happy with the Azenzis RT615's....but yet this same thing happened to me Twice.
your not going to get a free tire they are soft tires probably one of the softest tires that come on any car they go every 15000 miles or so with normal driving, just buy any cheap tires and call it a day you wont see that much of a diffrence
all of these tires mentioned are all season...
kumho mx is going to be an afforable tire and will last you a while... performance similar to stock..
i would go to mitsu and show them the tire... tires have a warranty against stuff like this.... shouldnt ever fall apart liek that
