Is this worth it?
Old Dec 28, 2007 | 09:19 AM
EgoBstr's Avatar
Is this worth it?
Questioning my bang for the buck. I have the following mods and am thinking of swapping out the following:
Currently have:
Megan manifold, O2 housing, DP, and race pipe in place of the cat.
GReddy Ti-C Catback
GReddy RS BOV
Walbro Fuel Pump
Injen LICP, UICP and intake
MBC
Considering swapping:
ETS 3" FMIC
Megan TP
How much awhp would each of these be worth considering I will be dynotuned before and after? I do not plan to mods the car anymore outside of this.
Thanks!
Old Dec 28, 2007 | 09:32 AM
UT_Evo's Avatar
So you're going to put in a FMIC (in place of the stock one) and a Megan Test pipe in place of the "race pipe"?
Or are you taking off everything you currently have and swapping in those two things? I'm confused.
Old Dec 28, 2007 | 09:36 AM
EgoBstr's Avatar
I am replacing the stock FMIC with a 3" one and replacing the race pipe with the TP.
Old Dec 28, 2007 | 09:39 AM
UT_Evo's Avatar
A race pipe and a test pipe are the same are they not? Or is that the situation where one has a resonator and one doesn't?
TP over a highflow cat can gain you around 10-15whp, I know that from dyno testing mine and a friend's Evo.
Old Dec 28, 2007 | 09:41 AM
gixxerman11's Avatar
i dont know proly like 15whp after tune
Old Dec 28, 2007 | 09:53 AM
EgoBstr's Avatar
Right, I have the race pipe which is a resonated test pipe.
Old Dec 28, 2007 | 09:55 AM
uSmC_08's Avatar
I have a resonated TP as well, but am thinking about ditching it for a non resonated one, I hope I'd pick up maybe 5whp?
Old Dec 28, 2007 | 10:18 AM
UT_Evo's Avatar
Are the resonated tp that much more restrictive than the regular tp? I wouldn't think so. But if they are, they have to be less restrictive than a high-flow cat, and therefore I would assume between 0-10 whp, more likely around 5.... Depending on the level of restriction.
As far as the IC, I have seen and read tons of things from gaining a bunch to simply having less turbo-lag and a better spool. I think it only works THAT well with a larger turbo, that's what I remember people telling me when I was looking, but its been over a year.
Old Dec 28, 2007 | 10:22 AM
housedj's Avatar
i'm going to say 0 gain on the pipe switch & 10whp more with the I/C if u have a good tuner. other than that u might have around 350whp tuned at sea level on 93octane & 22-24PSI... key words are good tuner
Old Dec 28, 2007 | 10:24 AM
ETS Michael's Avatar
If you plan on sticking with the stock turbocharger (doesn't show an upgraded charger on the mod list) The 3" will be perfect. If you do end up getting a test pipe i would recommend getting an o2 simulator or o2 faker, so you don't set off a check engine light.
The Tune is going to be the most important part of your setup.
If you have any more questions about our products, please check out our website http://www.extremeturbosystems.com or give us a call at 360-263-3748 - We will be more then happy to get you the right setup for your needs. We also carry the Megan Racing products.
Thanks,
Michael
(Posting on Tom's Name)
Old Dec 28, 2007 | 03:19 PM
krazirob's Avatar
YEAH ETS IS THE HEAT!!!!!!!! you wont be dissappointed if you go with ets bro
