looking for advice
Old Dec 30, 2007 | 06:01 PM
Draven83's Avatar
looking for advice
So i brought my evo to Ny from Hawaii. When picking it up from the shipping place i realized i had no heat. So drove from virginia to ny with no heat in low 30 degree weather. So i then took the car to a shop where a friend works at and he is now telling me that my head gasket is blown. But i know a little about cars and i am not smoking or losing any oil or anti freeze. So any idea what it could be? is there a chance i wouldnt have a thermostat in it? i am so lost.
Old Dec 30, 2007 | 06:55 PM
W0459732's Avatar
was it from HI to NY or NY to HI??
I think its ure thremostat
Old Dec 30, 2007 | 06:57 PM
bosox28's Avatar
I would go with thermostat also, after that drive what was your water temp at? If it wasn't at OT after that long of a drive then it's most likely the thermostat.
Old Dec 30, 2007 | 07:00 PM
bigric09's Avatar
its definitely NOT the head gasket and if your friend works a shop he needs to be fired and that shop needs to go thru a bit more detailed application process.
Old Dec 30, 2007 | 07:15 PM
Draven83's Avatar
it is originally from HI. and he said he did some sort of pressure test and it went to 22-23PSI. not quite sure what test it was he did. my temps after that drive were all fine. i drove for 9 hours straight except for gas and everything was normal. no smells or anything. is there a test to see if it is a thermostat?
Old Dec 30, 2007 | 07:31 PM
bigric09's Avatar
normally you will overheat if your thermostat is bad, but you could have possibly because of weather gotten lucky.
Old Dec 30, 2007 | 07:44 PM
fastkevin's Avatar
He pressurized your cooling system , which is what you can do when you suspect a BHG. Sounds like he found a breach. If your thermostat was stuck open it would just take longer for you (and your motor) to heat up. You can throw it in some hot water to see if it works. You'll need to have the water at the temp the thermostat opens. Depending on where the gasket breached, it is possible that coolant won't go into the cylinders or the oil. You know your buddy better than all of us. If you trust him, have him fix it. If you don't, take it to someone else. If you neglect a BHG, it can get really expensive in a hurry.
Old Dec 30, 2007 | 07:46 PM
Curt@MrLed's Avatar
Former Vendor
t-stat open, no heat, t-stat stuck closed, to much heat.. things go boom.
its easy to change.
Old Dec 30, 2007 | 08:17 PM
Draven83's Avatar
well i am taking it to emery up in rochester on the 1st. so i guess that says how much i trust my buddy
Old Dec 30, 2007 | 10:12 PM
k2boarder3187's Avatar
did he himself tell you that you had a blown head gasket or did the shop tell him to say that? If he is trying to pull a fast one he is a bad friend who is trying to screw you out of a lot of money saying he is gonna change the headgasket compared to the cost of changing a thermostat. Check your friend.
Old Dec 31, 2007 | 10:10 AM
Draven83's Avatar
he himself told me that.
Old Dec 31, 2007 | 01:17 PM
krazirob's Avatar
i take it you never used your heat in Hawaii uh??......LOL
i dont know if i would have made that ride
Old Dec 31, 2007 | 06:07 PM
Draven83's Avatar
that ride really sucked. i was freezing cold. took 2 days to get feeling in my feet
Old Jan 3, 2008 | 01:21 PM
Draven83's Avatar
So got the evo back today. turned out the old owner had the wiring all riged up and didnt connect it under the dash for the heat. works like a champ. and i got her tuned and got rid of the profec b. major difference. thanks for all the help and ideas.
Old Jan 3, 2008 | 10:27 PM
EmeryatSTM's Avatar
Glad everything worked out for you
-Em
