$12K budget..what to get?
Old Dec 31, 2007 | 12:49 AM
Freez's Avatar
hello everyone.. i dunno where to post this kind of threads so feel free to move it
anyhow, lately my friend and i are going into a kind of modifying competition. so im setting up a budget to get the most performance out of my evo as a weekend warrior and still keep it a DD.
i already own a few mods to start with, which are a Greddy IC with ICP's, 1000cc injectors aside. so i dont need to buy an IC nor injectors.
so i kinda need help on what to decide on here.. ur comments and feedback are much appreciated
Old Dec 31, 2007 | 12:56 AM
halfnhalfevo's Avatar
Get ready for a thorough flaming from all the haters
it'd be cool if for once someone in your unique position could just get some good advice and suggestions.
wish you the best.
Old Dec 31, 2007 | 01:06 AM
evonrp's Avatar
a k20 swapped eg hatch.....thats what i would do
Old Dec 31, 2007 | 01:07 AM
Johnboy1065's Avatar
I'd build the engine either with a built 2.0 or a 2.3 kit. the 2.3 might be better on the streets if you want it keep it a DD. and then get a 35r turbo kit preferably with the HTA 35R. then get a clutch to hold the power eg. exedy triple plate cerametallic. a dual fuel pump setup. and some sort of cams . and theres your performance. At least thats what I'd do with 12 thousand dollars. if you do ALL the work yourself this is doable.
Old Dec 31, 2007 | 01:17 AM
Freez's Avatar
getting a 35R was in my head. but a T67 just keeps popping in my head for some unknown reasons
and a triple plate?? u serious? i'll need to start working out if im gonna use a triple plate as a DD!
thnx for the input though, i'll keep it in mind
Old Dec 31, 2007 | 01:18 AM
Freez's Avatar
i think im more than happy with what i have, thnx!
Old Dec 31, 2007 | 02:31 AM
MTRJunior's Avatar
i have a exedy triple carbon...I love it, its not stiff at all
EDIT: Well.. it is a little, but its perfect for DD
Old Dec 31, 2007 | 03:12 AM
dxbevo9's Avatar
if i had to do it again..assuming i have a bone stock evo:
-BR built block-(2.0 or 2.3)
-BR Stg3 Head
-BR HTA35R
-BR TBE
-Boost controller
-BR Race intrcooler
-GSC s2 cams
-KW V3 coilovers
-some nice wheels and tires
instead of buying pieces here and there,,,
thats just me.
Old Dec 31, 2007 | 03:20 AM
pekpekbuster's Avatar
Everything from Lancer Evolution VIII MR FQ400 parts list
http://www.rsportscars.com/eng/cars/lancer_fq400.asp
Lancer Evolution VIII MR FQ400 parts list:
-Custom built Garrett GT Dual Ball bearing Turbocharger
-Owen Developments custom manufactured cast Stainless Steel Exhaust Manifold and Exhaust Elbow
-Omega Forged Pistons
-HKS Forged Con Rods
-HKS 680cc Injectors
-Zytec ITP116 High Pressure Fuel Pump
-HKS 1.6 mm Steel Head Gasket
-Motec M800 OEM ECU
-HKS Iridium Spark Plugs
-Jan Speed High Flow Sports Cat
-Alcon competition derived 240 mm high clamp mode, heavy duty clutch complete with Cera-metallic 6 paddle sprung centred drive plate
-HKS High Strength Head and Big End Bolts
-Alcon Mono6 Brake Kit incorporating Monobloc 6 pot road caliper with 343 mm curved vein Disc on a Aluminium mounting bell assembly with Ferodo DS2500 brake pads
-Carbon Fibre "Sharks Tooth" Rear Vortex Generator
-PIAA High Performance Light and Wiper Upgrade
Old Dec 31, 2007 | 07:11 AM
cssaddictm4's Avatar
In my opinion that would blow your budget and then some. I would do:
ETS T3 Turbo kit with your choice of turbo (3076R preferably or PT67) - $3,600
Buschur Turbo back Exhaust - $900
GSC S2 Cams - $550
EBay-AEM Wideband - $200
Boost & oil pressure gauges - $260
Choice of BOV - $200
Walbro Fuel pump - $100
AMS Fuel Press Reg - $300
Exedy or Tilton twin - $1700
3 Gauge pod -$60
ARP head studs - 100
Halman MBC- $100
With your injectors you probably need an AEM EMS, or you could swap them with 880cc's, AEM EMS $1700 includes 5 bar map and intake air temp sensors. You can free up this money with the smaller injectors and using ECUFlash which will probably yield the same results.
That leaves you with a bill of approx $9670 including shipping and 2330$ to spend on labor and tune. Tune will be usually 600-1000 from a good tuner. You looking at roughly 24hrs of labor including clutch install, from a good shop thats gonna probably run you $1440. That will leave you 300$ left over after getting a 600$ tune.
This will leave you with a 400-600whp car depending on the turbo. I made 480whp with my GT3076R setup.
Blake.
Old Dec 31, 2007 | 11:11 AM
your 1000cc injectors wont be enough to max out a t67 turbo. also You'll prolly need a triple plate or the tilton twin plate to hold the power for any length of time.
Old Dec 31, 2007 | 11:25 AM
GEJEN's Avatar
Heres your answer. Pick between buschur, ams or ets. Give them a call and find out what $12 large will get you. They can tell you install prices as well as the price of tuning etc... Good luck!
Old Dec 31, 2007 | 02:35 PM
W0459732's Avatar
what everyone else said. If u want the real bang for the buck, get a new litre bike like the R1, cbr 1000rr, zx 10r or gixxa 1000. U wont regret it.
Old Dec 31, 2007 | 02:38 PM
VtexGt3's Avatar
holy crap... thats alot of money to spend on the car.... i'd get a Jun 2.2 and a turbo that won't run out of breath cause i'd want to rev that baby up hiiiiiggghhh
Old Dec 31, 2007 | 02:45 PM
CGK's Avatar
CGK
I'd put $12K in my 401K...
