help with HID!
Old Jan 5, 2008 | 10:25 AM
silver evo8's Avatar
help with HID!
my driver side headlight will work fine as soon as I turn it on for about 20 seconds, then it will start to flicker and then it will eventually just turn off.
does this mean i need to replace the bulb or is there something wrong with my headlight?
Old Jan 5, 2008 | 10:28 AM
IfDontFITsPIT's Avatar
May be your igniter box... if it's the bulb it wouldn't turn on at all ?
Old Jan 5, 2008 | 10:32 AM
how can i target the problem?
Old Jan 5, 2008 | 10:38 AM
is it an aftermarket kit or is it the oem one ??
Old Jan 5, 2008 | 10:45 AM
pretty sure its the stock kit but I think it has upgraded bulbs (8600k)
Old Jan 5, 2008 | 10:48 AM
Curt@MrLed's Avatar
Former Vendor
switch bulbs. if the good bulb does it, you need a new ballast.
Old Jan 5, 2008 | 11:07 AM
how would i replace that and how much is it?
Old Jan 10, 2008 | 06:03 AM
hksevoix's Avatar
get an ebay kit
Old Jan 10, 2008 | 08:30 AM
DruMMinStUd06's Avatar
^ what he said...get a ballast/bulb kit for around $120...OEM is pretty steep...i think around $300 for the ballast alone? not sure...
Old Jan 10, 2008 | 09:19 AM
o2thag's Avatar
It sounds like a bad bulb. My friend with HIDs in his WRX had the same thing happen, the bulb would flicker and shut off. Like someone said, swap the working bulb into the place where the flickering one is and you'll know for sure if it's the bulb.
coreymelton
Jan 30, 2015 07:11 AM
wallie123
Aug 26, 2014 10:04 AM
sabotaaage
Apr 10, 2014 10:17 PM
warr40
Lancer Troubleshooting
Oct 7, 2009 08:39 PM
strtrcng426
Dec 1, 2008 09:40 PM
