Question about Highflow cat
Old Jan 7, 2008 | 10:36 PM
Erik@MIL.SPEC's Avatar
Originally Posted by Silver SRT4
Just get a test pipe, and be done with me . You got nothing to lose.
There are those who may not want test pipes:
1) People living in California ($1500 no cat fine IIRC)
2) People who don't like the annoying smell of a test pipe
3) People running in a street class that requires a cat
4) People who prefer to limit their impact on the environment
All others feel free to run test pipes.
Old Jan 8, 2008 | 06:51 AM
travman's Avatar
Originally Posted by MikeyLeblanc
Hey everyone. I have a 3" turbo back exhaust and i installed a high flow cat(megan racing) to pass the emissions test. My buddy says i should leave the high flow cat in because The hfc says it increases horsepower by 5-10. Will i get more horse power with the highflow cat or the test pipe and are there any problems with this? Thanks
I didn't know Megan had a real High flow cat?.....Are you sure you don't have a resonated test pipe because sometimes they are advertised as a high flow cats?
Does it look like this?
Megan Racing Test Pipe/Resonator- EVO
The Megan Raciing Hi Flow Catalytic Converter, also called a test Pipe or Resonator, allows more air flow thru the pipe, resulting in more horse power. The straight-through design is made with stainless steel with a chrome finish and is a direct bolt on.
* For off-road/race only*
Spec & Features
- 3" turbo inlet, works out great along with our downpipe and cat back.
- Increase air flow and performance
- 100% Stainless steel with chrome finish
- Bolt-on design, easy installation
Old Jan 8, 2008 | 07:03 AM
Burklow's Avatar
+1
I was under the impression Megan ONLY made their "High Flow Cat" which is a funny... If you look down the thing, it's clearly a test pipe. The only differences over the years were between their Evo VIII and IX test pipes. The IX one had a resonator whereas the VIII was completely straight through.
Check out like Perrin or someone for a true HFC. They aren't that expensive really, but isn't it a shame the most legal route for exhausts is the more expensive? lol
Old Jan 8, 2008 | 11:48 AM
MikeyLeblanc's Avatar
http://cgi.ebay.com/ebaymotors/Megan...QQcmdZViewItem
Stainless Steel High Flow Cat/ Resonator/ Test Pipe For Mitsubishi Lancer Evolution VIII(EVO 8) 03 04 05
* Model/Type:
Fit on Mitsubishi Lancer Evolution VIII(EVO 8) 2003 2004 2005
All Evo 8, Evolution VIII Model
* Dimension (Inlet/ Outlet):
Inlet 3 " (3.0")
Outlet 3" (3.0")
Length 18 1/4 "
O2 Sensor Hole: YES
Product Spec:
1. 100% High Quality Stainless Steel with Polish Finish Surface
2. Increase Air Flow and Performance
3. Compatible with stock exhaust system
4. No modification needed
5. Straight Thru with build-in RESONATOR, Direct Bolt-on Design for easy installation
6. Increase 5-10 Horse Power
7. Brand New Item
8.
This Hi Flow Cat Converter is for Car Show, Off Road, Race and Performance only
This High Quality High Flow Catalytic Converter, also known as Resonator or Test Pipe, enables more air flow through the pipe, thus increasing horse power instantly. This direct bolt on straight-through designed product is easy to install and compatible with all stock exhaust system. This product is made by stainless steel with a polish finish which can provide instant upgrade on performance.
This is what i have.
Old Jan 8, 2008 | 11:55 AM
* Model/Type:
Inlet 3 " (3.0")
Outlet 3" (3.0")
Length 18 1/4 "
O2 Sensor Hole: YES
Product Spec:
7. Brand New Item
8.
And that is a resonated test pipe, not a ceramic cat or a metallic cat.
Old Jan 8, 2008 | 12:04 PM
UT_Evo's Avatar
F the environment, what'd it ever do for you? j/k You already have bought a High flow, just keep that in and do your passengers (and yeah, the world) a favor, by not polluting and smelling like poop.
I kept mine the test pipe for a long time because my TBE came with one and I wasn't gonna spend 150 to lose hp just to decrease a little smell and save the world.
Also, just FYI, back when I got dynoed a friend had an Evo with about the same mods as me and 13 less WHP with a high-flow then I had with my testpipe. So, depending on the highflow, it can make a decent difference, but not worth the smell IMO
Old Jan 8, 2008 | 12:24 PM
I am willing to bet that was a ceramic cat. The differences should be much less when comparing a metallic cat to a test pipe.
Old Jan 8, 2008 | 05:56 PM
I'm confused now. Will i even be able to pass the emissions test with this? And is my old test pipe better than this?
Old Jan 8, 2008 | 06:42 PM
You will probably be able to pass emissions with a ceramic HFC. For maximum horsepower, you want either a testpipe or a 100 cell metallic cat. Testpipe you certainly won't pass emissions, and with a 100 cell you probably won't. Things can also be aversely affected by really aggressive cams, etc.
Your best bet would be to keep your OEM cat for emissions purposes and use either a 100 cell cat or testpipe for your everyday horsepower needs
Old Jan 20, 2008 | 01:53 PM
Here is an actual dyno compare between an Ultimate HFC and the 100 cell:
http://www.norcalevo.net/index.php?o...2280#msg422280
Ducky077
Nov 16, 2016 09:13 AM
nightwolf
Sep 9, 2007 11:07 AM
chapter8
23
Jan 7, 2005 09:33 PM
Gruppe-S
14
Sep 10, 2004 11:02 PM
Gruppe-S
Gruppe-S Engineering - California
Aug 30, 2004 01:19 PM
