HKS 272 cam question
Old Jan 10, 2008 | 02:06 PM
vipers's Avatar
well, im a rotary guy, so i honestly dont know the finer details of these crazy piston engines
im in the process of purchasing a set of 272 HKS cams for my evo IX, and am planning to get my car dyno-tuned in the somewhat near future...BUT, the question is....... can these cams be installed and driven on without any tuning done? would it hurt the motor? everything ive read on these cams says 30-40awhp AFTER tuning...
and if they dont hurt the motor (prior to tuning), would there be any noticable change prior to tuning? earlier spool, increase in torque, etc....i just wanna know how soon i can install these, or whether i have to install them RIGHT before i tune it
thanks everyone in advance for the responces!
Old Jan 10, 2008 | 02:13 PM
W_evo8's Avatar
tuned
Old Jan 10, 2008 | 02:15 PM
Nomad4g63's Avatar
are you going to replace the springs and retainers and arp headstuds?
Old Jan 10, 2008 | 02:21 PM
vipers's Avatar
HKS says they work fine with factory springs and retainers.... but i was planning to upgrade to ARP headstuds...... im not plannin g to go crazy with this motor for a while concidering its my DD
Old Jan 11, 2008 | 01:46 PM
TEAM ACE's Avatar
i drive mine every day with no tune . i throw a few codes but nothing major. the only thing that sux is that i over boost right away. and then i get the famous random misfire. i need to get some dough so i can get a tune and release the beast i have created. oh yeah i have the hks 272 and they are mean
Old Jan 11, 2008 | 01:53 PM
TURBevO8's Avatar
well just remember the whole point of cams is to allow more air into the engine. More air + more fuel = more power right? So if you are not getting tuned to add the appropriate fuel to the increased airflow you will be running lean. We all know lean is bad. I ran my 8 with HKS 272s for 3 weeks before getting tuned but made sure to stay under 12psi or so just to be safe. Now in reality you probably wont break anything daily driving but I would NOT go WOT with no tune and cams.
Old Jan 11, 2008 | 01:57 PM
chrismnj's Avatar
what else should be replaced with cams ?
Old Jan 11, 2008 | 02:01 PM
TURBevO8's Avatar
you dont have to replace anything. Most people do the head studs while they are in there and then you are set if you ever want to run high boost with race gas or meth or alky. And of course if you run some high lift cams you will need new springs. But you def do not with hks 272s. And if you never plan to run 28+psi there is no reason to do head studs either.
supafly_mx
Jun 10, 2015 08:55 AM
1BADSS/SC
May 22, 2015 04:23 AM
BEISSEN
Jul 14, 2010 06:03 PM
chris86530
May 30, 2004 12:06 PM
