Clock and headunit not powering up????
Old Jan 11, 2008 | 09:08 AM
mitsuEVO8kid's Avatar
Just yesterday my rear left speaker went out, so I decided to fix the problem. When I fixed the wiring for it, i turned on the ignition and heard the RL speaker kind of give a bass thud so i assumed it was back on.
Next thing i know my headunit Or clock is not turning on! Any ideass???
My car still turns on and headlights, turn signals, high beams, etc is in proper order its jsut the head unit and the clock. I already tried disconnecting the battery and retrying but they still did not turn on.
Please helppp
Old Jan 11, 2008 | 09:09 AM
TeStUdO's Avatar
Check you fuses.
Old Jan 11, 2008 | 09:10 AM
rcheung's Avatar
Originally Posted by TeStUdO
Check you fuses.
+1
It sounds like one of the interior fuses.
Old Jan 11, 2008 | 09:13 AM
Ryu123's Avatar
The fuse for that should be in the fusebox under the hood. It's in a yellow sleeve with 2 10A fuses in it.
Old Jan 11, 2008 | 09:14 AM
TeStUdO's Avatar
Also just for reference next time, always disconnect the negative terminal when working on any car wiring/electronics to avoid shorts.
Old Jan 11, 2008 | 09:15 AM
Hmm ill check it out right now and post pics in a few minutes. thanks for the quick responses!
Old Jan 11, 2008 | 09:18 AM
RoBear's Avatar
I had the exact same problems and this is the correct fuse! Getting them out of that yellow sleeve can be a pain.
Old Jan 11, 2008 | 09:22 AM
robyn402's Avatar
yea for sure happened to me.. belive its the memory fuse...
Old Jan 11, 2008 | 09:30 AM
Yeah they look okay but Im trusting you guys that they are the little pests ha. Is the only place to buy them?
Old Jan 11, 2008 | 10:01 AM
robyn402's Avatar
hell no, go to your nearest part store and pick up some mini fuses, pretty sure they're 10amp
although i went ito mitsu when it happened cuz i couldn't figure it out... service guy pulled it and gave me a box of them lol
Old Jan 11, 2008 | 10:57 AM
Ryu123's Avatar
They should be the ATM style fuses.
Old Jan 11, 2008 | 11:23 AM
TouringBubble's Avatar
I second (third, fourth?) that it sounds like a fuse. On a side note, it's always good to have a test light around to check fuses. you can pick them up cheap and they are very handy.
Old Jan 12, 2008 | 02:00 PM
Thanks much for the help guys. It was the 10Amp fuses. Bought a new set and clock and headunit turned on lol thanks again
