help with codes
Old Jan 13, 2008 | 09:05 AM
evoboi005's Avatar
help with codes
On my 2006 evo ix after i installed cams checked everything over before starting the car for the first time .... cranked the car for 10secs before we started it to try to build some oil pressure in the head and for the lifters that i did bleed (still trying to get them to fill back up and shut up)
but now i am throwing two does well really 3 .... p0011 twice and p0106 < which i found in the list of codes in the sticky but dont really know what would cause it and there is no code listting for p0011
can someone help me out thanks
Old Jan 13, 2008 | 09:22 AM
DonHugo's Avatar
I just looked it up in my book that came with the code reader
p0011 Camshaft position actuator A- bank 1 timing over advanced
Old Jan 13, 2008 | 09:42 AM
evoboi005's Avatar
hmm interesting
so would that cause the... Barometric Pressure Circuit Range/Performance Pro
and would this cause a stalling issue while the car was idle in the drive way etc...
Old Jan 13, 2008 | 10:32 AM
evoboi005's Avatar
ttt -need some input
Old Jan 13, 2008 | 02:25 PM
KcEvil8's Avatar
are you sure the cam sensor is in the correct position? and it not backward or 180degree off?
Old Jan 13, 2008 | 02:27 PM
KcEvil8's Avatar
and are u tune for the cams?
Old Jan 13, 2008 | 02:42 PM
smp3000's Avatar
Hey KcEvil how do you like the Crower cams?
Old Jan 13, 2008 | 02:55 PM
KcEvil8's Avatar
they are great cams for the price. not as lopy as the other cams.
Old Jan 13, 2008 | 03:31 PM
evoboi005's Avatar
how would i kno which sensor and it wouldnt run if it were 180 off would it and yes i have a tune for the cams..
