Battery Relocation Help please...
Old Jan 19, 2008 | 03:11 PM
bigric09's Avatar
Got a few questions for you and searching hasnt yielded the right info....
i am in the process of relocating my battery to my trunk. I have the battery and tray mounted to the trunk, i have ran the wire to the back...
my question is... the stock battery connections up front, do you have to keep the fuses connected and use the bolt thru method ? or can i cut the lines going to the terminal connectors and run them to my distro block like i had originally planned ? Im not really seeing the need for the fuses as i will have an inline fuse from the battery to the connections anyway. I realize it is there for safety, but im curious if that is the only reason and if anyone else has ran this type of setup without using the stock terminal.
Old Jan 19, 2008 | 03:34 PM
bigric09's Avatar
bump bump... would like to finish this up tonight
thanks in advance
Old Jan 19, 2008 | 03:55 PM
Joshs EVO's Avatar
Find out what the fuses are for. I left them. I put my battery in the trunk after my small battery took a dump. I just used another battery terminal too hook up to the termnal in the front and then ran the wire to the trunk
Old Jan 19, 2008 | 06:00 PM
bigric09's Avatar
the fuses id assume are for what fuses are normally for... if there is an over current condition or a short, they blow instead of causing more major problems. They will still be fused with my setup, the fuse will just be located in the trunk instead. i think i am just going to cut them and find out the hard way... worst case, i blow the car up lol... but more than likely it will work out just fine, and if i cut it, i can just resolder it if i have to.
Old Jan 19, 2008 | 07:24 PM
MR Turco's Avatar
As long as you somehow keep fuses on those lines you should be fine. You can get a fused distro block or an inline to replace the stock terminal.
Old Jan 19, 2008 | 07:39 PM
bigric09's Avatar
well, its done lol
i am going to fuse those lines in the trunk... i have a distro in the engine bay on a bracket i made and i have all the misc cables running to that as well as the other items that need a power source installed in the block... the battery is mounted in the trunk and im sure i will post a thread tomorrow after i am finished.... ill link that thread in here. Thanks for everyones input.
Old Jan 20, 2008 | 05:14 PM
bigric09's Avatar
Well, she is done... here is the thread as promised
https://www.evolutionm.net/forums/sh...61#post5176461
RalliartN
19
May 3, 2023 03:31 PM
KenyonKanye
Oct 2, 2016 05:20 PM
EVO GOES VROOM
Apr 27, 2016 07:58 PM
tsidrift1
14
Dec 8, 2013 04:46 PM
Luckiesralliart
Nov 29, 2012 09:51 AM
