05 MR Headlight Pattern
Old Jan 20, 2008 | 06:54 PM
EVOEMS's Avatar
I have an 05 MR, the car has GT Worx spriings which I love. The issue is his: the headlights are aimed a bit low, even when the height adjustment is all of the way up. Is there a way to get the headlights aimed higher? The car has a very small amount of positive rake which may be placing the pattern lower than stock, is there a simple solution to raise the light pattern?
Old Jan 20, 2008 | 07:01 PM
KenMasters's Avatar
A Phillips screwdriver in the correct lighting gear will put your beam wherever you want it.
Old Jan 21, 2008 | 06:23 PM
JDMCT9MR's Avatar
There are some threads that discuss this issue.Do a search for this issue and you will find your answer.
Old Jan 21, 2008 | 06:44 PM
pudge's Avatar
Yeah there is a way you can make the gears skip and change the settings, I know I have seen threads on this as well.
Black-X
Evo X How Tos / Installations
23
Aug 10, 2009 01:31 PM
Jason05RS
Dec 3, 2008 10:09 AM
EvoBlade2000
Oct 6, 2006 02:24 PM
mscc04
Jun 27, 2006 04:25 PM
flabarm
Nov 9, 2005 08:13 PM
