Mini battery dies after storage..help!
Old Jan 25, 2008 | 03:58 PM
Liqquid's Avatar
Originally Posted by J8dailo
i get about 0.5 volts instantly out of the mini battery...any ideas?? the battery is shot???
Unhook the positive lead from the battery, and see if the voltage goes up to 12 or so.. if it does, you have a draw on the battery from somewhere in the car. hook it back up and pull fuses one at a time to find where its coming from.
If it still sits at a half a volt, it's fried.... badly.
Old Jan 25, 2008 | 04:09 PM
ecko_3420's Avatar
get it checked at autozone..
Old Jan 25, 2008 | 04:12 PM
gixxerman11's Avatar
will the only reason you read 14 + is thats the alt pushing 14+ volts
Old Jan 25, 2008 | 10:55 PM
voidhawk's Avatar
sounds like you have a short somewhere ... btw, CF is a great conductor, friend of mine had the same problem and it turned out to be a CF valve cover shorting out on some exposed sensor wiring...
Old Jan 25, 2008 | 11:06 PM
Jameson_IXMR's Avatar
Heres a little bit of info, depending on the specs of the battery and how much of a load is on it with the car off, as well as environmental factors, if the battery is drained to a certain point it will lose its ability to hold a charge. This is why batteries go out to begin with, technically they are just boxes with corrosion inside. An anode and cathode in a pool of electrolytic fluid, one side eats away introducing electron flow in the process. By eats away, I literally mean eats away until it is no longer functional.
Toss in a new battery mabye from another car and give it a shot for a day or two. Occasionally battery tenders (the machine at autozone etc.) fail to diagnose this problem.
Typically higher output batterys maintain their stagnant charge for a shorter period of time, than economical batteries. You can never have the best of both worlds.....
Old Jan 26, 2008 | 05:03 AM
dsmfan95's Avatar
I crank mine atleast once a week, even if I don't drive it. Mine sat for about 3 weeks in the cold and it drained the battery but it charged up after driving it for an hour.
Old Jan 26, 2008 | 02:10 PM
J8dailo's Avatar
i bought a black and decker 1&2amp battery charger and hooked it up to charge...the battery voltage is at 1/2 volt and the light on the charger keep blinking from charge to full rapidly and after a while it just stops charging...i think those are what you called a battery tender...it makes no sense how could the battery be fried...i just didn't start my car for 2 months...any advices?? i am going to take it to autozone and have it recharged and tested to see whats wrong with it...thanks
Old Jan 26, 2008 | 02:20 PM
Evo8zip's Avatar
the batteries arent meant for cars. if you want a long term, no hassles solution, put a full size battery in your car. you'll be very happy
Old Jan 26, 2008 | 06:35 PM
fastkevin's Avatar
Originally Posted by kingman4
u need a battery tender (got it on ebay for $45ish shipped) if you're going to leave it for more than a week or two in the winter. I drive every day or at most i go a 2 days without driving, and my braille (deka) mini batt cranks like a champ.
DING DING DING DING!!
You install the leads once, and from then on all you need to do is plug it in.
Old Jan 30, 2008 | 02:54 PM
J8dailo's Avatar
i had the battery tested...it turned out to have an internal short from sitting in the cold for 2 months??....i guess there is no way to repair it.....thinking about relocating the battery to the trunk
Old Jan 30, 2008 | 04:36 PM
boostless's Avatar
Ding ding ding!!! once batteries are drained, they dont hold a full charge again. Get a new battery
Old Jan 30, 2008 | 08:33 PM
Liqquid's Avatar
That's what I was worried about... it can happen... just know that if you relocate your battery to the trunk, if you go to a drag strip they might give you **** for not having an on/off switch on the outside of your car!
Old Jan 30, 2008 | 08:35 PM
Flyin EVO 2's Avatar
I have a mini-bat in my car. I bought a $30.00 battery tender from Auto Zone. The car sat for 7 months, and the battery is still excellent. If you want to run a small battery for weight reduction, get a trickle charger with an automatic mode.
Old Apr 10, 2008 | 09:30 PM
Bexa20's Avatar
quick question, is it ok to charge the battery while positive and negative terminals are connected to it? Kind of similar setup like in jump starting the car.
Old Apr 10, 2008 | 10:25 PM
voidhawk's Avatar
I do this all the time when I'm out of town for more than a weekend (using a trickle charger). Doesn't seem to hurt anything as far as I can tell ...
Ryan Amini
Sep 19, 2014 06:54 AM
TK40
Feb 19, 2011 10:21 PM
sti killr
Jan 1, 2011 12:46 PM
Dragking2189
12
Feb 6, 2010 06:42 PM
Vibrant
Oct 29, 2008 06:07 PM
