Short Shifters
Old Feb 13, 2008 | 11:42 PM
MondoBongo's Avatar
Originally Posted by rEvolution420
https://secure.buschurracing.com/cat...3372f3454bfceb are those both base & underhood bushings or no? how much peices are both base & underhood bushings? isn't polyurethane bushings the best? lmk wen u guys get the chance, thx. i'm planning on getting the buscher racing short shifter & base/underhood bushings.
there are 6 bushings in total. two under the hood and four at the base of the shifter. those are just for the two under the hood.
i have poly bushings in the base, and buschur racing aluminum ones under the hood. they both work fine. but i don't know that you could say neccesarily that metal is better than poly or vice versa.
the BR bushings are a nice product, and reasonably priced. the e clamps can be a little tricky to get on, but with some needle nosed pliers to push on them, they go right on.
Old Feb 13, 2008 | 11:55 PM
spdracr's Avatar
this is one of my next upgrades
Old Feb 14, 2008 | 12:12 AM
spdracr's Avatar
i have brass bushings i havent installed but still deciding on my short shifter
Old Feb 14, 2008 | 12:19 AM
evo_man_06's Avatar
heres my opinion again
i think that ss are bad on your trannie and our trannies arent that great as is...unless shepard builds it for you
Old Feb 14, 2008 | 02:06 AM
Zeus's Avatar
I prefer the metal shifter bushings to poly... not a fan of short shift levers on Evos. I say do the bushings first, then see if you really think you NEED the SS.
Old Feb 14, 2008 | 02:34 AM
frenchy99's Avatar
The brass base shifter are good not under the hood though. They tend to lock out because they need to warm-up in order for them to function properly. I have tested both brass under hood and poly urethane bushings. I can tell you the poly urethane works better under the hood bushings especially in cold weather. Just my 2 Cents!
Old Feb 14, 2008 | 02:49 AM
rEvolution420's Avatar
poly is plastic and sumtimes tend to break though or no? another question - are these metal bushings compatible with the 9's too? or are they different from the 8's? http://lancershop.com/customer/produ...3&cat=6&page=1 i'll probably go with metal base and under hood, unless the poly r really better for under the hood ones.. still debating on which ss to get- kartboy, b&m, or the buschur one, hmmm...
Old Feb 14, 2008 | 07:07 PM
any input on whether or not these metal base bushings will be compatible with the 9's? http://lancershop.com/customer/produ...3&cat=6&page=1 think ima grab these if they're compatible along w/the buschur under hood aluminum bushings.. any input would be highly appreciated, thanks.
Old Mar 4, 2008 | 09:21 PM
Drooke's Avatar
ok i was looking at getting a short shift till i just read all this and saw that u can change the bushings wat does changing the bushings do ?
4g63girl
Mar 16, 2014 07:44 PM
r3z0nate
Midwest Region
Aug 1, 2007 06:42 PM
Mirage2.0
Lancer Tranny/Drivetrain Tech
32
Jan 18, 2007 03:15 PM
2StepsAhead
12
Oct 10, 2006 02:13 PM
90GSX-03EVO
14
Jul 17, 2003 07:06 PM
