Smooth shifter?
Smooth shifter?
Anyone have a shifter kit that makes the GSR less notchy? Ive been reading up on short shifters and feeling various cars...a friend has a kartboy shifter + bushings and its still notchy and stiff...then I tried a stock MR and its VERY smooth/not notchy which is what I want. I see some people say the B&M's reduce notch and a weighted shift knob will help out too.
I have a forge motor mount as my first thing to cure a little of the notch while under load, but I sat in the MR last night and rowed the gears and it felt smoother (I know the shifter is taller therefore it is easier to get into gears) I was hoping there was some shifter that just decreased the notch...seems like some people have it, some dont...mine isnt bad but after feeling the MR shifter I liked it.
The motor mount really helped with high RPM shifting...it goes in like butter. But normal shifting around 3-4k rpm are still notchy, I even have all the shifter bushings too. The only thing that helps the shifts is if you pause slighting in nuetral before shifting into the next gear. I still cringe everytime I change gears and it nothces in...I HATE it so bad, but you have to take the bad with the good. I just hope it is not killing my gear synchros since i just had them replaced on the TSB.
Originally Posted by evo150
i am going to try pennzoil syncroshift first to help with the notchy gears. if that doesnt help i am going to get the forge front motor mount
Syncroshift only helps a little. The motor mount helps much more. Hoewever, neither will get rid of the notchiness completely.
Originally Posted by 2StepsAhead
I thought all the IX's had teflon coated shifter pieces. I notice the notch with the car off and just rowing the gears vs the MR's.
I thought we got it too..
https://www.evolutionm.net/forums/sh...d.php?t=184809
https://www.evolutionm.net/forums/sh...9&postcount=24
mikebuff35
10
Feb 22, 2016 12:11 PM
Tmracer22
Oct 31, 2015 03:43 PM
Paulito
May 31, 2009 09:23 PM
