just got an EVO VIII need some advice
Old Feb 1, 2008 | 10:17 AM
aKeenanWithaEV0's Avatar
i got an EVO VIII a few weeks ago and it had a Greedy Profec B spec 2 boost controller. I dont really know exactly how to use and it is giving me some problems, i also just figured out that i have a boost leak and i know its some where in the throttle body.
if anyone has any advise for me i would really appreciate it.
Old Feb 1, 2008 | 10:19 AM
kidneythief13's Avatar
you should try posting in the Evo 1-9 forum
Old Feb 1, 2008 | 10:20 AM
Sorry, my bad - haven't had my coffee yet.
Old Feb 1, 2008 | 10:29 AM
sharkm87's Avatar
well from readin here and there, i think i read a few post about throttle body seals leaking, and there was a write up on how to fix that exactly...as far as usint the boost controller..i dont know, never had an ebc, but try greddy website for a manual. unless someone chimes in.
Old Feb 1, 2008 | 01:44 PM
drive01's Avatar
Evo's are prone to leaking:
http://www.cobbtuning.com/info/?ID=3481
One of the not so obvious problems (like ic pipe coupler leaking) is the throttle body shaft seal. http://www.worksevo.com/store/produc...roducts_id=415
For $20, its a good piece of mind
Old Feb 1, 2008 | 01:53 PM
insanechief's Avatar
Good luck on the EBC there confusing!!!!
Old Feb 1, 2008 | 03:02 PM
AndyBandy's Avatar
that EBC is sort of a pain in the nuts, but i had to get my throttle body shaft seal replaced as well. I had a shop do it for me, just because i hate messing with the TPS sensor.
this shouldnt affect your EBC too much, just because your boost controller will keep iterating to maintain full boost setting, but you def. will lose boost up top. I think i still have the starter settings here somewhere, but post your settings and how much boost you'd like to run.
Old Feb 1, 2008 | 03:06 PM
kaonashi's Avatar
profec b is junk id take it out and go a different route. I've had 2 buddys end up blowing a engine cause the solenoid got stuck open and boost went threw the roof.
Old Feb 1, 2008 | 04:32 PM
Tevenor's Avatar
If you want an EBC, there are better. Did it have a boost gauge to go along with the controller?
Old Feb 1, 2008 | 04:53 PM
v-manracing's Avatar
I have the same boost controller and it's been working fine for me, you just have to play with the settings untill your happy with the response. My buddy and I spend about 2 hours doing 3rd gear pulls to set the high setting, the response was good and boost climbs really fast, it peaked out at 24.6psi tapering to 22.5 to 23. we still got alot of tweaks to do but have to wait for better weather the low setting I left the same as the high and is working fine , the settings I used are
GAIN- 16%
SET GAIN-73
Old Feb 1, 2008 | 04:55 PM
GAIN- 16%
SET GAIN-73
WARNING-22
L.-20%
I hope this helps
Old Feb 6, 2008 | 02:44 PM
JUNKGSX's Avatar
I've always had good luck with my apexi avcr. yeah it takes a little bit longer
to get used to than the average electronic boost controller but well worth it
as far as quality and performance.
