New mods Maney problems
Old Feb 2, 2008 | 08:33 AM
SpeeDeviL's Avatar
you sure, won't that result in any kind of exhaust leak?
Old Feb 2, 2008 | 11:41 AM
PVD04's Avatar
When I was on the stock turbo I never used extra nuts on the O2 housing and never had exhaust leak issues.
-Paul
Old Feb 3, 2008 | 01:00 AM
SpeeDeviL's Avatar
But the turbo makes a loud noise when it start spooling now, is this normal whe installing an O2 housing.
A friend of mine has the AMS FMIC, and megan O2 housing, and he said it dosen't make that noise
Old Feb 3, 2008 | 01:20 AM
Jameson_IXMR's Avatar
Okay, is there any way you could post a soundclip of the "sound"? As far as the exhaust leak check, simply start your car, have someone stand near the tail pipe with a towell, and plug the exhaust for just one second (no more!) meanwhile you get near it and check to see if you hear any hissing. Exhaust leaks are easy to troubleshoot this way. About the innovate LC-1, I just installed mine and had several problems. First the terminator plug wasnt given to me by innovate, they sent one. Then the Sensor was bad, but this gave me an E-2 error, I used a multimeter to read through the 2 middle pins on each row and it was 9 ohms, which was bad. I got that sent next day, and not the xd-16 will not connect to the laptop, because it will not power up unless hooked to the lC-1, so I have to send the xd-16 back. If I get one more problem with this thing, I am getting a refund and getting the AEM.
Also, sounds like you should get a new mechanic asap.
Oh, when I installed my FMIC and piping (with no leaks verified) the turbo spool sounded whispy-ier? More whistle-like.
Also sounds are different with different downpipes/o2housings ect, so unless your setup is the same, you cant really go by that.
Old Feb 3, 2008 | 12:36 PM
SpeeDeviL's Avatar
Jameson_IXMR you just descriped the sound, it sound like a turbo spool with a whistle-like sound, I did a boost leak and eveything seem to be okay no leak what so ever, so either am freaking out or there is an exhaust leak, I'll get everything checked tomorrow.
I have a full TBE with test pipes and an intake.
as for the innovate I might get the AEM, I did everything I can with this damn thing, and it dosen't seem to work, I hate it so much.
as for my mechanic I already got a new one and am not going back to him ever again.
Old Feb 3, 2008 | 05:36 PM
Liqquid's Avatar
Originally Posted by PVD04
You don't need nuts for the O2 housing. The flange is threaded.
-Paul
+1 you don't use a nut with that setup, I have the same setup on my car. The gasket in question would be between the O2 and the turbo itself... however even with a leak, I would think the WG should still control boost enough for you to not spike that high..
Old Feb 3, 2008 | 09:28 PM
SpeeDeviL's Avatar
the boost spike was there because my STUIPED *** mechanic did not connect the boost controller hose that go to the turbo nipple, because I got the BR deluxe FMIC with the LICP that come with out a nipple so he left it as it is with out connecting it.
When we found out about the hose, he wanted to weld the hose on the UICP, I started my car and left the damn place with out saying a word.
I went back home and connected the hose to the BOV and WAALAAA, it works, no welding nothing, a simple T fitting and that’s it
Old Feb 3, 2008 | 09:41 PM
sharkm87's Avatar
lol, but on the stock LICP the nipple is covered when you get a MBC, so i dont get what that would have to do with anything at all ? **scratches head**
...lol but anywho, good job on driving outat that place..wtf was he welding a nipple on the UICP for...what an idiot
Old Feb 4, 2008 | 07:06 AM
SpeeDeviL's Avatar
it depands on you, you either can cover it or connect it to the MBC, its your choice.
as for the sound of the turbo, I'll try to get a video so you guys can hear it.
Old Feb 4, 2008 | 07:23 AM
Redline06's Avatar
You dont need nuts on the to of your DP/02 Housing flange.. the flange is threaded and the the stock bolts are spring loaded.. that's good enough.. and if you use different bolts.. still no need for nuts.. only if you are one of those super secure guys.. lol
As for the Boost controller.. I know what you mean about the J pipe of the turbo not having a Nipple.. but hey, why not weld a nipple onto the new J pipe.. that's what I did..
Yes, T'ing off your BOV vacuum line works, but not the greatest option for me as its sharing vacuum pressure which tends to lead in a lil bit of inaccuracy on the way your boost gauge and your Boost controller work.. not a lot but is existent trust me..!! Actually the mechanic was in the right direction but its just not that practical in the UICP.. takes to much time to make your shiznit work..!
As for the turbo check to see if there is any shaft play.. after a work out like that..! lol prob. nice to check it..!
Old Feb 9, 2008 | 01:53 AM
Any luck on the exhaust leak? You figured out the other problems correct?
Old Mar 23, 2008 | 01:17 PM
SpeeDeviL's Avatar
Hey guys after goin though almost everything, I finally decided to check the turbo and here's what I found.
The wired thing is, the car still pulls hard and you can feel the power coming when the turbo spools, my question is:-
Is that normal or this is the beginning of the end (turbo burn)?
I found a place that can fix the turbo, and change the damaged part with new a one, well that work?
Please help me out guys, thanks.
Old Mar 23, 2008 | 01:25 PM
Wicked E's Avatar
First thing I would want to do before I looked for a place to repair it was to find out WHY and WHAT caused that to happen. That is some serious turbo damage.
Is your MAF honeycomb still intact?
Cheers-
E
Old Mar 23, 2008 | 01:51 PM
XIEvolutionIX's Avatar
OT but i thought of a new one:
you know your an evo owner when destroyed turbos make your cringe more than dead bodies.
Old Mar 23, 2008 | 03:25 PM
evoboi005's Avatar
ouch that isnt good... wonder what was in there to do that ...
