Boost Leak test
Old Feb 8, 2008 | 09:55 AM
jonjon123's Avatar
Boost Leak test
Did a search and couldnt find anything. Would someone either direct me to a how to or give me the information on how to do a boost leak test. thanks in advance
Old Feb 8, 2008 | 09:57 AM
EvoDan2004's Avatar
take off your intake
connect your boost leak tester to the turbo
pump air into it using a compressor. NOT a bicycle pump
listen for leak fix and retest
Old Feb 10, 2008 | 10:49 PM
voidhawk's Avatar
If you apply pressure to the intake and the throttle body is closed, wouldn't the control line to the BOV see lower pressure and open the valve? I'm still trying to find the best / easiest way to do leak check, that's why I ask?
Old Feb 11, 2008 | 01:39 AM
Jameson_IXMR's Avatar
I used to use a bike pump back in the day.
Old Feb 11, 2008 | 06:42 AM
CrackerJackToy's Avatar
I used a bike pump the other day, and got it up to 12 lbs of pressure LOL
Old Feb 11, 2008 | 06:43 AM
dcorn's Avatar
Old Feb 11, 2008 | 11:33 AM
Joehunk's Avatar
https://www.evolutionm.net/forums/sh...ight=leak+test
Searching this forum can be a chore due to noise level.
Old Feb 11, 2008 | 06:24 PM
andreww238's Avatar
if you hear the air coming out.. somewheres and your not positive of what it is. you can use like soapy water around the area and look for bubbles.. used this trick with the talon and found a few around the throttle body
Old Feb 11, 2008 | 06:58 PM
voidhawk's Avatar
incense or cigarette smoke works pretty well too
