exhaust manifold..
Old Feb 9, 2008 | 03:23 PM
jonny5's Avatar
get a mini torch heat it up and lossen it my experience of removing o2 sensor that cant be removed by pb blaster
Old Feb 9, 2008 | 03:31 PM
vvhiteix's Avatar
like i said its too stripped for anything right now. its garbage..need a new one.. anyone know how much it will run?
Old Feb 9, 2008 | 05:38 PM
biggie5252's Avatar
The Front o2 sensor (SN4-126) is $48.67
http://oxygengeek.com/item.wws?sku=S...tid=oxygengeek
This is copied from another thread. Thank topnitroracer.
Old Feb 9, 2008 | 05:54 PM
whoang40's Avatar
Yep what he said, I couldn't get mine off and ordered another one online. Soldered the wires to the harness and upgraded my O2 housing. It's just a waste of time to get that sensor off.
Old Feb 9, 2008 | 05:58 PM
vvhiteix's Avatar
the link doesnt work....
Old Feb 20, 2008 | 11:19 PM
Inprogress's Avatar
http://www.oxygengeek.com/item.wws?s...tid=oxygengeek
Old Feb 20, 2008 | 11:20 PM
iBOOST's Avatar
good deal
Old Feb 21, 2008 | 12:23 AM
Jameson_IXMR's Avatar
Originally Posted by vvhiteix
ok well...that was prolly the easiet part...i dont know how anyone could get the o2 sensor off with the o2 housing still attached inside the car....seems d*** near impossible...
Unbolt the lower heat shield so it can move freely but hangs on the sensor wires. Then get under there and heat the o2 housing (not the sensor) with a blowtorch and use an open ended 22mm wrench to break it loose while its hot. Really easy.
Old Feb 21, 2008 | 07:59 AM
1320 Engineering's Avatar
There is a very detailed how to on evomoto that deals with taking off the manifold....
