exhaust manifold..
Old Feb 8, 2008 | 10:49 AM
vvhiteix's Avatar
exhaust manifold..
how do i get my exhaust manifold off...im swapping out the o2 housing.. one of the threads on it are stripped...but i have the L bracket removed from the o2 housing and my downpipe is off as well obviously...it just doesnt seem to flex enough to get my exhaust ,manifold off...is there anything else i have to remove?
Old Feb 8, 2008 | 10:53 AM
Thegame's Avatar
Just manhandle it. Honestly, it will come off. The turbo oil and coolant lines are made to bend slightly. I went after mine with a pry bar. The right side is the hard side.
Old Feb 8, 2008 | 11:12 AM
KillaItalian904's Avatar
lmao.... manhandle it. well i wouldent do it that way too much as you bend and break an oil line from doing that constantly. There is a bracket screwed into the stock O2 housing that bolts it to the block of the car. if you dont remove this than manhandle-ing it would be useless. there is a howto on this if you just look around more. whenever i do this i disconnect all the lines and drain the oil just to make absolutely sure nothing happens especially if you have not don it on an evo before. The bolts will be hard to remove and more than likely break make sure to use plenty of pb blaster. Plan ahead plenty of time dont plan on finishing in an hour your first time thats for sure
Old Feb 8, 2008 | 11:57 AM
pwrofturbo's Avatar
Pull. Hard.
Old Feb 8, 2008 | 02:39 PM
Kracka's Avatar
These guys are right, use some muscle and it will come! Use plenty of PB Blaster, that stuff is great.
Old Feb 8, 2008 | 02:54 PM
vvhiteix's Avatar
ok well...that was prolly the easiet part...i dont know how anyone could get the o2 sensor off with the o2 housing still attached inside the car....seems d*** near impossible...
Old Feb 8, 2008 | 05:03 PM
fox2boost's Avatar
go to the hardware store and else the guy where they keep the elbow grease, lol no but seriously pb blaster works wonders
Old Feb 8, 2008 | 05:12 PM
DanJ's Avatar
i had trouble finding the right tool to remove the nuts that attach to the manifold, are people removing it with a socket wrench.
Old Feb 8, 2008 | 05:48 PM
EvosnatcH's Avatar
i pulled my rad just so i could get more leverage, i know a little over board but some of those bolts are a biotch to get to, and yes i gave my o2 housing a beat down as well
Old Feb 8, 2008 | 07:41 PM
urslo4n8's Avatar
I had to remove the whole turbo/manifold/O2 housing because i had stripped one of the studs to the hotside and CANNOT get the freaking thing off, So while the whole things off im gonna do some mods. You CAN take the manifold off without even removing the O2 bracket to the block ive done it before. You have to slightly wedge the turbo foward to the front with a padded prybar of some sort while workinig the exhaust manifold foward. It helps to take the oil line to the turbo off from the block
Old Feb 8, 2008 | 07:53 PM
vvhiteix's Avatar
alright so anyway...i still cannot get the o2 sensor out of the o2 housing.. think i rounded it to much for a regualr wrench have to try a socket... does anyone know how much that o2 sensor set up is.?
Old Feb 8, 2008 | 07:56 PM
EVOlution561's Avatar
You have to use an open wrench, you can't get a socket to go over an o2 sensor. Put some pb blaster or wd40 and let it sit 10 minutes you will get it off.
Old Feb 8, 2008 | 10:17 PM
Jameson_IXMR's Avatar
PB blaster and WD-40 should be stocked in your garage, sometimes it's the difference between removing a bolt and stripping it.
Old Feb 8, 2008 | 10:25 PM
eponti's Avatar
You need to remove the LICP thats on the turbo outlet side so that you can push the turbo down then pull out your exhaust manifold.As far as the 02 sensor tap the housing a little bit to break it loose.
Old Feb 9, 2008 | 03:16 PM
vvhiteix's Avatar
yea well ended up stripping it...so now i need that o2 sensor harness...has anyone purchased one to know how much it is...?
