Evo Problem...Help!
Old Feb 18, 2008 | 07:10 PM
rolly1818's Avatar
Registered User
Evo Problem...Help!
when the car is idling, for some reason if i turn the steering wheel the rpms rise...this happens whether the car has warmed up or not!
WTF? lol..what is causing this...? HELP
Also, there is weird squeaking sound from under the car, someone told me that, i should grease my strut bar mounts in the engine bay?
What are the gaps on the stock Evo IX plugs (NGK Part # ILFR7H)?
Old Feb 18, 2008 | 07:14 PM
EatSleepBoost's Avatar
could just be something goin on with ur power steering pump putting more strain than it should on the belt causing the engine to compensate and raise rpms so it doesn't stall. check for bulletins
Old Feb 18, 2008 | 07:22 PM
Mag00n's Avatar
99% sure thats totally normal. every car ive had with power steering has done. the power steering uses energy from the motor to assist you
Old Feb 18, 2008 | 07:25 PM
03RRVIII's Avatar
how much RPM thus it increases by?
Old Feb 18, 2008 | 07:47 PM
evohang's Avatar
Yeah I have the same problem but honestly i couldn't help you but to tell you its no biggie.
Old Feb 18, 2008 | 07:49 PM
evokel's Avatar
+1 hes right.
Old Feb 18, 2008 | 08:46 PM
Drooke's Avatar
tune will help a little, mine was doing the same thing i got my car tuned today and now it stays at a good 850rpm ideal
Old Feb 18, 2008 | 08:53 PM
sekula's Avatar
Same thing here, whenever I turn the wheel, the rpm's go up about a 100...
Mag00n is right, I've had it in every car so far that I've owned...no big deal.
Old Feb 18, 2008 | 08:57 PM
CrackerJackToy's Avatar
No biggie. Mine does the same.
Old Feb 18, 2008 | 09:04 PM
evo_man_06's Avatar
i hate power steering...if i didnt have a wife and child i would buy a delete kit...same deal here no worries
Old Feb 18, 2008 | 09:14 PM
DSM GSR04's Avatar
Wow man, Its called "Power steering". The power comes from the power steering pump which gets its power from the motor, in oder to move the steering rack and power the pump the rpms must rise. You have no buisness owning a sports car if you dont know this common knowledge.
Old Feb 18, 2008 | 11:19 PM
JDMCT9MR's Avatar
Not a problem man.My car does this as well.
Old Feb 18, 2008 | 11:28 PM
nemosEVO's Avatar
LOL, mine does to, its your power steering...lol
Old Feb 19, 2008 | 02:34 AM
rolly1818's Avatar
Registered User
lol thanks for all the repsonses...i figured it was normal..just wanna be safe.
it only raises like 100rpm...Thanks!
any other replies to my other 2 questions?
Old Feb 19, 2008 | 02:58 AM
wrcRS's Avatar
Strut Bars don't squick. You must mean Sway Bar. You can lubricate your sway bar bushings.
