Fitment of Oil return line
Old Feb 8, 2008 | 05:11 PM
vexgaffer's Avatar
I have an 2003 Evo 8 and I bought 2 oil return lines so far but it just wont fit!!! The end that connects to the oil pan is angled the opposite way. Anyone have any ideas to fix this i tried bending the tube where the flexible part is but still doesnt work...someone help me out please
thanks
Old Feb 8, 2008 | 05:32 PM
scottatyamaha's Avatar
It may be best for you to remove the manifold to the turbo that way you have some flexability to move things around.
Old Feb 8, 2008 | 06:55 PM
vexgaffer's Avatar
picture of the fitment.
so you can see that its like a half inch off. not sure what happen here. just wonder if other people had to force there oil return line or what.
does this look like the last owner put a different pan on?
Last edited by vexgaffer; Feb 8, 2008 at 06:55 PM. Reason: picture didnt not show up.
Old Feb 9, 2008 | 07:03 AM
sabastian458's Avatar
I use to run into this same issue when working on the Evo's. The trick, I found out, is to loose both the top 2 bolts and the bottom bolt. Dont take the top completely out, just enough to be able to move the return pipe. Then after doing so, you can manipulate the pipe to where it needs to be, put both bottom bolts in, not tightening completely either. After getting both sets of bolts in, tighten the top bolts first until snug, then the bottoms until snug, then go back and torque them down correctly. BE SURE that on the bottom bolts you have the small o-ring/washers on, or you WILL get an oil leak.
Old Feb 9, 2008 | 12:55 PM
vexgaffer's Avatar
So I tryed doing it the above way, and had no luck. The space is just to big to force it in. I have some pictures of the holes can anyone tell me if they look off to yall.
any advice would be awesome.
Old Feb 9, 2008 | 12:58 PM
bigric09's Avatar
im guessing you are trying to use IX lines on an VIII or vice versa. Whatever block you have, you have to make sure you order lines specific to that model. They are not interchangeable... at least, not without a whole lot of force you dont need.
Old Feb 9, 2008 | 03:30 PM
zwickyc's Avatar
I was in your situation before in where I bought new oil return line for my 2005 and it didnt fit at all. I ended up using the old one. Funny thing, about a month later I was working on a 2003 and the oil return that didnt fit my year ended up fitting perfectly on his. The oil return part number that fit the 2003 was MR464925.
Old Feb 9, 2008 | 03:57 PM
vexgaffer's Avatar
hmm well the thing is the frist one we order was brand new. couldnt even heat up the metel hot enough to twist it to place. so we order one from someone on here. and it was off his car. which was a 03 8. so it should of fit. but it didnt X_X. so we are stuck here a week in to this hour long project... my friend is think about buying a flex line off some website. I think its like extremepsi or something. not to sure of the name.
Old Feb 9, 2008 | 04:47 PM
zwickyc's Avatar
You could also try http://jnztuning.net/shop/catalog/in...Path=22_56_264. That was my next plan if I ever need to take the turbo off again.
Old Feb 9, 2008 | 06:01 PM
sparky's Avatar
..... BE SURE that on the bottom bolts you have the small o-ring/washers.....
Small o-ring washers? Are they small rubber o-rings, or metal washers with a rubbery center?
Old Feb 9, 2008 | 06:12 PM
kaonashi's Avatar
Negatron, Ive had 3 oilpans and 3 lines from different models all 3 the same. I was actually using a 8 oiline on my IX block cause the one sent to me had a crack.
BTW the line i sent him was off of an 8 turbo.
Old Feb 9, 2008 | 06:16 PM
kaonashi's Avatar
Is your oil pan loose? it looks like you have a gap up there.... Verylast pic
Old Feb 9, 2008 | 06:24 PM
i just thought of something. try flipping the return pipe upside down. (180 degrees) and try reinstalling
Old Feb 9, 2008 | 06:48 PM
kaonashi's Avatar
why dont you bolt it to the oil pan first like i did then bolt it to the turbo
Old Feb 9, 2008 | 11:06 PM
vexgaffer's Avatar
ya heres what im going to get because of the fitment issues with the oil return line. Already bought 2 oil return lines didnt fit so might as well try this.
http://www.extremepsi.com/store/cust...cat=336&page=1
