Advice on next mods
Intercooler pipes serve zero gains over stock.
Only one gear is available to be replaced on a 2006 Evo with MIVEC variable intake cam.
Lower IC pipe alone is the only slight benefit from anything mentioned.
pretty much my finding so far...
cosworth kills the gsc by at least 10 in whp and tq and cosworth kill the hks in hp and run close with tq.
i could see if you posted this in evo general in your own thread.... but geesh
OK i drive a 05 ralli and yest im in the wrong forum but i need some help with conversion and maybe some of you are familiar with the ES OZ and RA. My issue is that outside of RRM not many people make parts for my car including body kits but there are plenty for you ES types so my question is will the kits for the ES bolt up to the RA and same with fenders and CF doors. Any feedback is great.
Even though two of them say the exact same thing, these were all posted in different threads! If you can figure out how to hit "ctrl + C" and "ctrl + V" then you can figure out how to navigate on a forum. It really isn't much harder than reading, pointing, and clicking.
LAZY!
Haha nice quoting...
What's everyones take on recirc BOV, more for sound or any noticeable gains? Intake piping stock is ok? (just have a cone filter attached to stock).
Also Brian Crower Cams, not nearly as good as Cosworth 272 MIVEC Cams? Thanks!
The stock intake piping (black plastic hose) is fine really. The metal units are known to cause some drivibility issues such as idle due to the fragile MAF sensor. With a tune it should run fine with metal intake pipe and filter, but sometimes they don't. One plus side to a metal pipe would be a louder DV sound though.
I like the Cosworth cams over the Brian Crower ones because of dyno proven gains. I'll be ordering a set of Cosworths in a few months, but don't let my opinion stop you from looking and doing some deeper research into the two brands. Cams are just great on Evos, but some have a few more gains than others.
A recirculated blow off valve won't get you any gains. You shouldn't consider a BOV as a performance mod. If anything, you could say that a recirculated BOV will recover lost horsepower that a plastic OEM Evo 8 diverter valve leaks out, but since you have an Evo 9, you don't have that leaky plastic valve problem.
