evo 9 underdrive / light pulleys ?? removing balancer shaft??
Old Feb 16, 2008, 07:31 AM
EE
EE's Avatar
Hello,
I was wondering how much gain would be achieved from replacing my evo 9 pulleys with underdriven / lighter ones... and removing the balancer shaft...
of course, underdriven pulleys hv side effects...
any one having data on this subject (underdrive and lightweight vs lightweight vs stock, gains & side effects. Also regarding balancer shaft removal...) is most welcome to comment.
Rgds+
Old Feb 16, 2008, 07:43 AM
CBRicahrd's Avatar
i have not seen much info on under drive pulleys, i would also like some input from others that have done this.
from what i've read, the balance shaft is best left alone, unless you plan on going high hp and high RPM.
Old Feb 16, 2008, 08:05 AM
BBS
BBS's Avatar
Is this for a daily driven car? If it is, save yourself the headache and leave them intact.
Old Feb 16, 2008, 08:09 AM
Drooke's Avatar
I would stay with stock if ur not pushing high hp numbers its not really worth the money
Old Feb 16, 2008, 08:19 AM
EE
EE's Avatar
okay, so wt abt hp gains??
Old Feb 16, 2008, 10:30 AM
EE
EE's Avatar
bump
Old Feb 16, 2008, 03:49 PM
RedLanEVO's Avatar
Haha, I will say this. Stay with your stock pulleys, period. With underdrive pulleys, your engine will not last as long. The stocker is designed to dampen crankshaft twists and vibrations that underdriven pulleys will not. If you build your engine, you will probably want to go with aftermarket fluid dampeners.
Old Feb 16, 2008, 04:28 PM
EE
EE's Avatar
okay, so what abt lighter crank pulley?? this is not underdriven, only 4 lb lighter than sotck..
i can underdrive only the alternator and power steering pulleys, and install a lighter crank pulley...
Old Feb 16, 2008, 05:39 PM
RedLanEVO's Avatar
^no
Old Feb 17, 2008, 06:49 AM
EE
EE's Avatar
hahaha, okay i get the point...
but wt abt hp gains??? how much hp gain from a lightweight cranck pulley can u get??
Old Feb 17, 2008, 07:24 AM
BBS
BBS's Avatar
That depends on the engine load/speed. It's like flywheel weight reduction. The benefits depends on the load of the engine. I'm not going to guesstimate either sooo yea.
Old Feb 17, 2008, 10:22 AM
EE
EE's Avatar
say 250% at peak power 6500 rpm???
Old Feb 18, 2008, 01:18 AM
EE
EE's Avatar
bump
Old Feb 18, 2008, 02:56 AM
popadel's Avatar
Cant see there being any ill effects from a lighter pulley. I.E. not under-driven.
I put them on Scoobs and Evo's all the time and have yet to see any issues after many years of use across many customers.
the hlp rev easier above 4500RPM. lower down they dont do much different to OEM.
Adelin
Old Feb 18, 2008, 03:21 AM
EE
EE's Avatar
wt abt 3-4% underdriven?? wt hp gains??? just a rough number...
Quick Reply: evo 9 underdrive / light pulleys ?? removing balancer shaft??
