detonation
Old Feb 23, 2008 | 07:57 PM
3SgteGuru's Avatar
I don't think its fuel cut, Fuel cut usaly stops the car cleanly and abruptly. Its not like a fuel cut to make a bang. I would say put the STock BOV on with it recirculated and see if that fixes it. If not even go and put the stock airbox. Then report back.
Old Feb 23, 2008 | 08:30 PM
sparky's Avatar
Yeah, fuel cut. Get a tune(flash) as it is probably running way rich. Some Evo's, mine included, don't like too much fuel when going WOT in the midrange. Mine is doing this right now at about 3400 RPM and 22 PSI. If you look in the rear view when it happens you'll probably see a huge cloud of black smoke when it happens. You need the fuel table leaned out via a flash.
Incidentally, what are you doing with that Godzilla on your Evo? Is it recirculating, or venting to the atmosphere? Get an original Mitsubishi metal DV on there ASAP.
Old Feb 24, 2008 | 12:58 AM
Liqquid's Avatar
hmmm.... ok it's a drop in filter, no biggie, and a VTA blowoff... anything else on the car that's not stock? The BOV might be causing problems, but I can't see a stock Evo with a drop in hitting "boost cut" or fuel cut... I thought you had an intake, not just a drop-in
Old Feb 24, 2008 | 01:27 AM
urslo4n8's Avatar
It could be just to the fact that youd be getting max boost in 4th or 5th gear as compared to 1st or 2nd. i.e. you might hit 21-22 in 1st or 2nd but 24-25 in 4th and 5th and maybe the timing is too advanced for the setup or octane
Charlescrown
May 5, 2014 01:58 PM
AlainD
10
Feb 9, 2011 10:23 PM
rt turbo
12
Sep 1, 2010 09:24 PM
ikt
Jun 21, 2010 03:38 PM
feldguy
Nov 22, 2004 03:18 PM
