UICP blew off...now bad cat?
Old Feb 25, 2008 | 09:49 PM
bluebyu36's Avatar
Originally Posted by rodman
Coincidence? Maybe, but there were other people reporting the same thing when it happened to me.
ya who know, just logically it dont make sense...
Old Feb 25, 2008 | 10:01 PM
rodman's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=203759
Read through my original post as many had a CEL after this happens. Go figure
Old Feb 25, 2008 | 10:16 PM
Skywarp's Avatar
Wow. this happened to me at about about 5k miles (completely stock).
Old Feb 26, 2008 | 09:50 AM
junction's Avatar
That is wierd since it is stock. Mine did that a few times, but had mods. So I started carrying extra clamps and tools in the car. It is very important to line up just right and tighten real tight otherwise it will keep happenin. First time it happened to me I was like . Anytime since then I was like "Damn that hose popped AGain!" and pulled over to fix.
Never had any cels cuz of this. Vacuum hose pop as well? My car came with a turbo timer which had a boost guage built in and the dealer decided they would disconnect the boost gauge so they plugged the hose going to the boost gauge and left the vacuum hose to the intake open, go figure. This caused a cel to be thrown randomly till i figured it out. If they want to replace your cat then why not.
Old Feb 26, 2008 | 02:09 PM
Burklow's Avatar
I just bought a 3" T-bolt clamp, but they only had one. I was installing it in my driveway, but it was too cold to finish. I really don't feel like making room in the garage right now to work on it, but I know it'll fix my little problem of "POP! there goes the boost..."
How common is a LICP blowing off? I'm going to replace all the clamps with T-bolts eventually, but now that I will fix my weakness at the TB, I'd be scared a IC pipe would come off somewhere where I couldn't reach easily on the side of the road. eg. I'd have to take the bumper off for the LICP, yes?
Old Feb 26, 2008 | 05:52 PM
VRSF Tiago's Avatar
Just because it supplied that code doesn't neccessarily mean thats the exact problem.
That code could have been pulled up due to the UICP blowing off and causing certain sensors to think your catalytic converter is clogged/defective.
I'd just tighten the clamp, purchase a t-bolt clamp to replace it or upgrade your UICP and have the code cleared.
Old Feb 26, 2008 | 06:03 PM
gsrboi80's Avatar
This could be related. As a P0420 code is Cat efficiency below threshold meaning that the exhaust gasses after the cat are still to dirty (to put it simply). So since your IC pipe popped of causing the car to dump major fuel. This could very well result in crapy O2 readings post cat thus said CEL. Once you fix your crappy Clamp you should be fine.
Old Feb 26, 2008 | 07:22 PM
rodman's Avatar
Does anyone think that when this happens under cirtain conditions (throttle position/boost/load/how long the car'runs' without hose on) the massive amount of now unburned fuel (ecu is calculating much fuel under boost and without a maf reading, even at idle uses a 'rich' formula) makes it's way to the O2 sensor and or cat and kills one of the two?
I remember when it first happened I actually recall trying to get the car to keep going for abit. Not like a mile, maybe 100 yards Then on the side I let it run thinking it would fix its self untill I realized it was time to shut her down and pop the hood. Yea, not the brightest thing to do, but it was my first Evo and only had it a month. Never figured it would happen, much less fubar the O2 and or Cat
Someone do a search on how many IX cats were replaced under waranty since they came out, lol.
Old Feb 26, 2008 | 07:48 PM
evo420's Avatar
i just sprayed a small bit of hair spray on the conections and make shure the clamp is right along the edge of the rolled edge. and havent had any problems.
Old Feb 26, 2008 | 07:49 PM
evo420's Avatar
but wait at least 24 hours to drive
Old Feb 26, 2008 | 07:59 PM
junction's Avatar
I replaced my LICP without taking the front end. You got to pull the undertray and it takes some handy maneuvering with angular ratchet extensions and such. Good performance mod tho .
Old Feb 26, 2008 | 09:24 PM
wizzo 8's Avatar
Wow I never thought of doing that. Thanx for the advice. I will try that if I get a poor connection even with t clamps
EvoSeanzie
Jun 20, 2010 06:18 PM
EVLVD 8X
Apr 28, 2006 11:33 AM
JuancaROD
Feb 21, 2006 01:12 PM
Hungbee112
Dec 22, 2004 10:10 PM
Blue#2
Nov 9, 2003 01:36 PM
