The "Official" Evo Modding for Dummies
Old Oct 21, 2008 | 10:57 PM
  #181
RoadSpike's Avatar
Originally Posted by luischav3z
exactly wat tune needs to be done when the intake is replaced?
Typically maf scaling or smoothing.
With the HKS suction intake you got to compensate for the fact that at high rpm/boost the intake tricks the maf into thinking there is a lot more air coming in than there is really.
Old Oct 22, 2008 | 12:51 PM
  #182
luischav3z's Avatar
thanks..
Old Nov 8, 2008 | 06:51 PM
  #183
abazaba410's Avatar
What is the lean side of the Air/Fuel on an Evo 8? I know high side is 12.5 but mine is running at about 10.7 it seems lean to mean but wanted to double check
Old Nov 8, 2008 | 07:15 PM
  #184
RoadSpike's Avatar
are we talking about WOT and full boost?
On pump gas , 93 octane, it would be silly to run it leaner than 11.5 Afr. On the 91 octane here you really want to be just below 11.0 AFR i run 10.8 to be safe. There isn't a lot of power to be gained by running the edge of lean so people tend to go richer to be safer.
Race gas is different since the octane is so high you can run 12.0 AFR even with high boost.
Try not to get confused with running with E85. A wide band sensor is setup using a lambda sensor. The AFR you see on the gauge is a multiplier against the lambda. So when running e85 14.7 AFR with a gas wide band is still 1.0 Lambda. Since gas AFR's are easier for people to grasp than lambda most people will recommend running just around 11.8 AFR on e85.
Old Nov 9, 2008 | 07:59 AM
  #185
chaotichoax's Avatar
RoadSpike for president? holy wealth of information
Old Nov 9, 2008 | 10:04 AM
  #186
abazaba410's Avatar
yeah wot and full boost
Old Nov 16, 2008 | 03:20 PM
  #187
angl0528's Avatar
Awsome post def learned alot from it thanks!!!
Old Nov 17, 2008 | 10:37 AM
  #188
SiniC's Avatar
^^100% agreed
Old Nov 24, 2008 | 07:39 AM
  #189
stikiller214's Avatar
this help me out alot
Old Nov 24, 2008 | 04:04 PM
  #190
aka03's Avatar
good thread for people
Old Nov 25, 2008 | 06:43 AM
  #191
prodystopian's Avatar
Originally Posted by chaotichoax
Tune:
The most common method of tuning these cars now a days is a simple reflash. Evos have a few programs available for download that have tons of logging parameters and can be used to log and tune these cars. Any evo tuner can do this for you or you can do everything yourself with a laptop/Tactix cable/programs. You can get the car street tuned or dyno tuned. Either way, a tune is the true way to unlock the potential of an Evo. It gets you the most out of your mods and allows proper adjustment for fuel/boost/etc. Bottom line, GET A TUNE!!!
- I only mentioned a reflash because it is the most sensible option for someone new to modding
- Search the forums for tuners in your area or those that offer mail in flashes.
- Increases power as well as gas mileage.
- A TUNE IS THE MOST WORTH WHILE MOD FOR THIS CAR - WHETHER YOU INTEND TO MOD IT OR NOT!!!
Are there any good resources for how to tune the car myself ('03 Evo VIII)? I looked in the tuning section for older evo's but I couldn't find a guide on how to go about tuning.
This mod guide is a great resource.
Old Nov 25, 2008 | 09:31 AM
  #192
RoadSpike's Avatar
Generally i deal with EcuFlash so you can read up on this great article.
https://www.evolutionm.net/forums/sh...d.php?t=302895
Old Nov 25, 2008 | 10:28 AM
  #193
That is exactly what I was looking for. Thanks!
Old Nov 25, 2008 | 11:14 AM
  #194
tommimakinen8's Avatar
Nicely done. I'm a newbie so this one really works for me.
Old Nov 25, 2008 | 02:26 PM
  #195
abazaba410's Avatar
I have a quick Cam question. Now I know that Cams are probably the best bang for my buck. I have recently done a few mods to my car, and in December I will be getting a tune. But I was curious.... If I do cams is it going to ruin my drive-ability at all? My Evo has 76k miles and is my daily driver. I dont want to lose any reliability or create problems. I would be going small like a 264, but stock spring and retainers.
