Looking to change all my fluids soon.
Hey guys I'm looking into getting all my fluids changed on my evo 8 and I was just wondering what are some good brands to go with and where I can go to get them.
i'm about to do mine...diaqueen for the differential fluids, pennzoil synchromesh for th tranny, mobil 1 10w30 for the oil...and my brake fluids, power steering fluids, and engine coolants are still good to go.
When it comes to adding oil to the transfer case measure the amount out and then you will know how much was added to the case. If you look to see oil drip out it may do that even when the transfer case is not competely full.. Just an FYI.
+1 exept i run brad penn 20w50 for oil
every oil change since ive had it.
You are going to hear some many different opinions on which fluid you should use. The key is to use what is recommended from Mitsubishi. Look in your owner's manual to see what the recommended specifications are for each fluid and then go from there.
Pure Playaer
74
Nov 25, 2009 08:17 AM
shawn360h
14
Mar 27, 2009 09:07 AM
One more question though...What kinda engine coolant should I use and brake fluid? Also I want to do the 60k tune up and I'm not sure what I need to get.
On the use of Redline in the diffs and transfercase... Hold onto your wallet...
