340 whp peak on a Mustang dyno
Old Mar 7, 2008 | 03:31 PM
tatsuIX's Avatar
I need some expert estimation (without actually going to the different dyno's) what would be my numbers on a DD and the DJ and is it true that the Mustang dyno's run lower than the others and if so how much lower? I just figured that I would have better numbers than what I currently have
Trying for that magically number of 400 w/o meth, is it even possible on 91?
Old Mar 7, 2008 | 03:47 PM
evogottago's Avatar
340whp on a mustang dyno is some good power. I'm pretty sure that the other types of dynos run between 30-40 whp higher than a mustang. And for your second question, I havn't heard of anyone getting 400whp without at least a turbo upgrade, although with a turbo upgrade and no meth it's possible
Old Mar 7, 2008 | 03:48 PM
evogottago's Avatar
O woops.. just saw that you're running 91... hmm .. not sure if you could hit 400 with 91 unless you got a good size turbo
Old Mar 7, 2008 | 03:52 PM
Erik@MIL.SPEC's Avatar
340 on a Mustang is probably approaching 390+whp on a DynoJet. 400whp is possible, but you'll need every bolt-on possible.
Aby@MIL.SPEC (formerly WOT) has made 415whp on 91 with an EvoGreen, Cosworth M2's, Weapon-R intake manifold & AEM on Reese Tuning's DynoJet. Maybe you can hop on there and see what 340whp on a Mustang translates to.
Old Mar 7, 2008 | 07:28 PM
tatsuIX's Avatar
Erik@MIL.SPEC, actually i have an appointment with Reese Tuning next weekend for a 65mm TB install and maybe a retune.
Old Mar 7, 2008 | 10:56 PM
PM me you numbers as I'm pretty close to 340 MD whp, and I'd love to see how it translates. Like I said, I think it might be 390 or so on a DJ.
Old Mar 8, 2008 | 01:20 AM
evozakk's Avatar
I just dyno'd at 394 on a DD. Green, TBE, 272's, upper and lower IC pipe and intercooloer, intake, exhaust manifold, o2 housing. I have a 2.3l though. He could have squeezed more but we are good until I adjust timing and tune for meth..
Old Mar 8, 2008 | 11:12 AM
R9's Avatar
R9
nice
Old Mar 8, 2008 | 12:14 PM
You and your damn 93 octane
Old Mar 8, 2008 | 12:30 PM
gixxer6's Avatar
Hmm I would definitely get re-tuned because Im making 318 whp on mustang dyno with mods in sig and a tune from mynes. With your mods you should be at lest 350whp, Im Running 21lbs of boost what are you running?
Old Mar 8, 2008 | 02:48 PM
evozakk's Avatar
haha, well I think with boost control and timing it would have been better. I was just trying to throw out a somewhat close comparison but forgot you were on 91
Old Mar 8, 2008 | 02:50 PM
tatsuIX's Avatar
25 psi peak and levels to 21 at 7700. So you think 350 on MD? what are your afr's
Old Mar 8, 2008 | 02:53 PM
tatsuIX's Avatar
remember I'm also stuck with that super fuel we have down here called 91
Old Mar 8, 2008 | 02:56 PM
Boltz.'s Avatar
FCOTM Winner
get in touch with razorlab. Hes tuned a bunch of evogreens on a mustang dyno.
I made 327whp on a mustang with stock evoVIII turbo, basic boltons, and 93oct. My car is not average however.
Old Mar 8, 2008 | 03:00 PM
Normanruben's Avatar
i hit 385 on 91 on a dj. i am in san diego as well, but i got tuned at tuning tech.
